Why Do Spherical Capacitors Have Equal and Opposite Charges?
Spherical capacitors consist of a metal sphere and an outer metal shell, which, when a constant voltage is applied, result in equal and opposite charges on the two plates. This phenomenon is due to the conservation of charge; when a positive charge (+Q) accumulates on one plate, an equal negative charge (-Q) must appear on the other plate. The connection between the two conductors facilitates the transfer of charge, ensuring that the total charge remains conserved throughout the system.
  • Understanding of electrostatics and charge distribution
  • Familiarity with the principles of capacitors
  • Knowledge of conservation laws in physics
  • Basic concepts of electric fields and potentials
  • Study the principles of electrostatics in detail
  • Explore the mathematical modeling of capacitors
  • Learn about charge distribution in conductors
  • Investigate the effects of varying voltage on capacitor behavior
Students of physics, electrical engineers, and anyone interested in understanding the behavior of capacitors and charge conservation in electrical systems.
center o bass
If you have a spherical capacitor consisting of a metal sphere at an inner radius and an outer metal shell at an outer radius.. then you apply a constant voltage over the two plates.
Why is it so that the two metal plates will have the same total charge? Is this by conservation of charge?
Im thinking that it might be because if +Q goes to one sphere and charge can not be created, so therefore -Q has to go to the other? Is this correct?
I think I was a bit too fast posting this question :)
I figured it must be because the two conductors are connected such that a current of charge runs from the one to the others. Hence -Q goes to one leaving the other with +Q.
  • · Replies 18 ·
