Physics problem (olypmic long jumper)
  • Thread starter Thread starter lmf22
    Physics
The Olympic long jumper, with a horizontal speed of 8.7 m/s, covers a distance of 8.5 m, resulting in an airtime of 0.977 seconds. The analysis utilizes kinematic equations to determine the maximum height achieved during the jump, calculated as 0.477 m. The vertical motion is influenced by gravity, which is factored into the vertical displacement formula. This discussion effectively breaks down the problem into horizontal and vertical components for clarity.
  • Kinematic equations of motion
  • Understanding of horizontal and vertical motion components
  • Basic principles of projectile motion
  • Knowledge of gravitational acceleration (9.8 m/s²)
  • Study the application of kinematic equations in projectile motion
  • Learn about the effects of gravity on vertical motion
  • Explore advanced projectile motion problems involving varying angles
  • Investigate real-world applications of physics in sports performance analysis
Students studying physics, coaches analyzing athletic performance, and anyone interested in the mechanics of projectile motion in sports.
lmf22
An Olympic long jumper is capable of jumping 8.5 m. Assume that his horizontal speed is 8.7 m/s as he leaves the ground, and that he lands standing upright, the same way he left the ground. How long is he in the air?
How high does he go?
I'm stuck and don't know where to start except that it involves the distance formula in the X and Y components.
Actually, I don't see that you need to worry about y at all!
You are told that his horizontal speed is 8.7 m/s and that he covers 8.5 m horizontally. Just ignore the vertical motion. How long does it take to go 8.5 m at 8.7 m/s?
To solve this problem, we can use the kinematic equations of motion to find the time and maximum height of the long jumper.
First, let's break down the motion of the long jumper into two components - horizontal and vertical. The horizontal component is given as 8.7 m/s and the vertical component is unknown.
Using the formula for distance, we can write:
Horizontal distance = Horizontal speed * Time
Since the long jumper travels a distance of 8.5 m, we can write:
8.5 m = 8.7 m/s * Time
Solving for time, we get:
Time = 8.5 m / 8.7 m/s = 0.977 seconds
This means that the long jumper is in the air for 0.977 seconds.
Next, we can use the formula for vertical displacement to find the maximum height.
Vertical displacement = Initial vertical velocity * Time + (1/2) * Acceleration * Time^2
Since the long jumper starts and ends at the same height, the initial and final vertical velocities cancel out. Also, the acceleration due to gravity is acting in the opposite direction of the jumper's motion, so we take it as negative.
Therefore, the formula becomes:
0 = (1/2) * (-9.8 m/s^2) * (0.977 seconds)^2 + Vertical displacement
Solving for vertical displacement, we get:
Vertical displacement = 0.477 m
This means that the long jumper reaches a maximum height of 0.477 m.
In summary, the long jumper is in the air for 0.977 seconds and reaches a maximum height of 0.477 m.
  • · Replies 20 ·
