Polarized Light Reflection: Solving for Intensity
The discussion revolves around the physics of polarized light and its reflection from water surfaces. Participants are exploring how the angle of inclination affects the intensity of light passing through polarized sunglasses.
  • Participants discuss the relationship between the angle of the sunglasses and the intensity of light that can pass through, referencing the formula for intensity. There are questions about the correctness of calculations and the factors influencing the results.
There is an ongoing exploration of the problem, with participants questioning their assumptions and calculations. Some guidance is offered regarding the interpretation of results, but no consensus has been reached on the correct approach or final answer.
Participants are considering the implications of leaning at an angle and how that affects the perceived intensity of polarized light, with some uncertainty about the calculations involved.
mli273
1. A person riding in a boat observes that the sunlight reflected by the water is polarized parallel to the surface of the water. The person is wearing polarized sunglasses with the polarization axis vertical.
If the wearer leans at an angle of 17.0 degrees to the vertical, what fraction of the reflected light intensity will pass through the sunglasses?
2. I =I(initial)cos^2(theta)
3. I tried I/I(initial)=cos^2(17) which yielded .91 but that was not correct. What factor am I missing here?
If the person is vertical, zero gets through, right?
If they lean just a leeeetle bit to the side, how much should get through?
9/10ths?
Intuitively, does that make sense? Intuitively, what does make sense?
that's true, I didn't think of it like that. So would it be 1-.915 which is .085. Thank you!
Never trust a calculator. Use and trust your common sense. The tool just gets you the decimals.
IMO, that's the one big lesson students need to learn.
  • · Replies 25 ·
  • · Replies 16 ·
