Finding the Angular Distance Between Jupiter and its Moons (Galilean)
The discussion focuses on calculating the angular distance between Jupiter and its Galilean moons: Io, Europa, Ganymede, and Callisto. The key method involves understanding the telescope's field of view (FOV) to determine the apparent distance between Jupiter and its moons. For instance, if the FOV is 1 arcminute and the distance to a moon is half of that, the angular distance is 0.5 arcminutes. Alternatively, one can calculate the true distance to the moon and use the distance from Jupiter to derive the angle.
  • Understanding of angular measurements in astronomy
  • Familiarity with telescope specifications, particularly field of view (FOV)
  • Basic knowledge of celestial mechanics and distances in space
  • Ability to perform trigonometric calculations for angular distance
  • Research how to calculate angular distance using trigonometry
  • Learn about telescope field of view and its implications in observational astronomy
  • Explore the concept of apparent versus true distance in celestial observations
  • Investigate software tools for simulating celestial positions and distances
Astronomy students, amateur astronomers, and anyone interested in observational techniques for measuring distances in the night sky.
Dreyth
I am having the hardest time figuring out the angular distance between Jupiter and Io, Europa, Ganymede and Callisto!
I asked my teacher for help: "How would one find the angular distances between Jupiter and its
moons?"
and he said: "Do you know the field of view of your telescope? Once you know that,
you can just compare the apparent Jupiter-moon distance to the full
width of the field of view.:
I'm must be just missing something. Can someone help me by either explaining what he meant, or by giving me a somewhat easy (it's late) way of finding it out for myself?
Astronomy news on Phys.org
What he's saying is that if you know your entire field of view (FOV) is 1arcmin, and the apparent distance between Jupiter and a moon is half of the FOV, then you know the angle is half an arcmin.
Otherwise, you could find out the true distance between Jupiter and the moon, and use your distance away from Jupiter to calculate the angle.
  • · Replies 27 ·
