Gravitational Potential Energy Derivation question?
The discussion revolves around the derivation of gravitational potential energy, specifically the relationship between work done by gravity and changes in potential energy. Participants explore the implications of integrating the gravitational force over a distance and the conventions used in the equations.
  • Participants discuss the integration of the gravitational force and the directionality of the vectors involved. Questions arise regarding the treatment of negative signs in the equations and the implications of the limits of integration. Some participants express confusion about the conventions used in writing the equations and whether alternative formulations could be valid.
There is an ongoing exploration of different interpretations of the equations and their implications. Some participants have provided guidance on the treatment of the gravitational force and its direction, while others are still seeking clarity on specific examples and the generalization of concepts.
Participants are working within the constraints of homework rules, which may limit the depth of exploration into the derivation process. There is an acknowledgment of the potential for confusion regarding the signs in the equations and the assumptions made about the direction of motion.
sponsoredwalk
In deriving the gravitational potential energy term I have a question.
[tex]W \ = \ \int_{r_1}^{r_2} \overline{F}( \overline{r}) \cdot \,d \overline{r} \ = \ \int_{y_1}^{y_2}mg \,dy[/tex]
[tex]W \ = \ \int_{y_1}^{y_2}mg\,dy[/tex]
[tex]W \ = \ mgy_2 \ - \ mgy_1[/tex]
[PLAIN]http://img696.imageshack.us/img696/2303/workvk.jpg
[tex]W \ = \ mgy_2 \ - \ mgy_1 \ = \ U_{grav}_2 \ - \ U_{grav}_1[/tex]
I think I understand that y2 < y1 and that is the
reason why people write the above as:
[tex]W \ = \ mgy_1 \ - \ mgy_2 \ = \ U_{grav}_1 \ - \ U_{grav}_2[/tex]
but is it such a crime to just be aware of the y2 < y1 and
write the equation in the more logical fashion that the straight calculation gives
you. To me it seems similar to how you rewrite the equations of constant
acceleration the standard way the calculus shows them and you mentally
set g = - 9.8 m/s²
Just like to hear some thoughts on this, thanks!
Hi sponsoredwalk,
There is a problem here with the second integral. Remember that the dot product depends on the direction of the vectors, and that this force is downwards.
set g = - 9.8 m/s²
I don't see the problem, the force is w = mg and the direction is downwards so both
the force and direction are in the same direction ergo there should be no minus.
What am I missing?
[tex]\overline{F} \ \cdot \ d \overline{r} \ = \ mg \ \hat{j} \ \cdot \ (\ dx \ \hat{i} \ + \ dy \ \hat{j} \ + \ dz \ \hat{k} \ )[/tex]
[tex]\overline{F} \ \cdot \ d \overline{r} \ = \ mg \ dy[/tex]
What am I missing?
The dy is positive; the limits that you have put in there handle the fact that you are actually moving downwards. (At least, that is why you are getting a different answer. There are other ways to interpret it, but that is the easiest.)
(Also, you know the work done by gravity as the box moves down is positive, and yet you are getting a negative work.)
Hmm, I'm still a little confused I must admit. Thanks a lot for the help, I think if you could
help me as I explain a specific example I think it'll be easy to generalize from it.
Say I'm dropping a 10kg box from a point 10m above the ground, say y1 = 10m
to a point 2m above the ground, y2 = 2m. The force acting on the box is
[tex]\overline{F} \ = \ - \ m \ g[/tex]
[tex]W \ = \ \int_{y_1}^{y_2} \ \overline{F} \ \cdot \ d \overline{r}[/tex]
[tex]W \ = \ \int_{10}^{2} \ (- \ m \ g ) \hat{j} \ \cdot \ dy \ \hat{j}[/tex]
[tex]W \ = \ - \ m \ g \ y \ |^{2}_{10}[/tex]
[tex]W \ = \ - \ m\ g \ (\ 2 \ - \ 10 \ )[/tex]
[tex]W \ = \ + \ 8 \ m\ g \[/tex]
W = 800 J (g = 10m/s² for convenience).
I assume the calculation for the general term for potential energy follows a similar
pattern? I mean, I should count F as (- mg)i and then the minus will cancel out if
we are moving in the direction of motion or remain if we go against gravity?
If I do this the derivation goes as follows:
[tex]W \ = \ \int_{y_1}^{y_2} \ (- \ m \ g ) \hat{j} \ \cdot \ dy \ \hat{j}[/tex]
[tex]W \ = \ \int_{y_1}^{y_2} \ - \ m \ g \ dy[/tex]
[tex]W \ = \ mgy|^{y_1}_{y_2}[/tex]
[tex]W \ = \ mg_1 \ - \ mgy_2[/tex]
[tex]W \ = \ U_1 \ - \ U_2[/tex]
[tex]W \ = \ - \ (U_2 \ - \ U_1)[/tex]
and voila? :biggrin:
Looks good to me!
alphysicist said:
Looks good to me!
GREAT! :biggrin::biggrin::biggrin:
Thanks for the help, enjoy the day/night/humidity/warmth/[insert_temporal/environmental_circumstances_here] :biggrin:
My pleasure! And I liked the question; I remember doing exactly the same thing long ago while deriving the U = -G M m/r form of the gravitational potential, and wondering why the minus sign was not showing up for me.
  • · Replies 23 ·
  • · Replies 46 ·
