Weyl curvature and tidal forces
The discussion revolves around the relationship between Weyl curvature and tidal forces in the context of Friedmann-Robertson-Walker (FRW) metrics. Participants explore the implications of conformal flatness, the nature of tidal forces in different spacetimes, and the definitions of Weyl and Ricci curvature. The scope includes theoretical considerations and conceptual clarifications related to general relativity.
  • Some participants assert that a manifold is conformally flat if its Weyl tensor vanishes, suggesting that the universe described by FRW metrics is conformally flat and thus has Weyl curvature equal to zero.
  • Others argue that this interpretation conflicts with the definition of the Weyl tensor, which is said to express tidal forces experienced by bodies in geodesics, indicating that there may be non-zero Weyl curvature in certain contexts.
  • A participant points out that in FRW spacetimes, tidal forces are spherically symmetric and arise from matter density (Ricci curvature), not from Weyl curvature.
  • Technical details are provided regarding the scale factor and the nature of tidal forces in FRW spacetimes, emphasizing that these forces are due to the matter distribution rather than vacuum solutions.
  • Some participants express confusion about the relationship between Weyl curvature and tidal forces, questioning whether a vanishing Weyl tensor implies no tidal forces.
  • There is a discussion about the implications of vacuum solutions and how Riemannian curvature relates to Weyl curvature in conformally flat manifolds.
Participants do not reach a consensus. There are competing views regarding the implications of Weyl curvature and tidal forces, with some asserting that tidal forces in FRW spacetimes are due to Ricci curvature, while others maintain that Weyl curvature plays a role in certain scenarios.
Limitations include potential misunderstandings about the definitions and implications of Weyl and Ricci curvature, as well as the conditions under which tidal forces manifest in different spacetimes. The discussion highlights the complexity of these concepts without resolving the ambiguities present.
TrickyDicky
I'm a bit confused about this and would like for someone to help me get this straight.
I read in wikipedia that a manifold with more than three dimensions, like spacetime, is conformally flat if its Weyl tensor vanishes. I think all FRW metrics are conformally flat, so I guess our universe is conformally flat and that means a Weyl curvature=0 in our spacetime manifold, doesn't it?
But this seems at odds with the wikipedia definition of the Weyl tensor that says it expresses the tidal force a body feels in a geodesic, specifically the part about how the shape of the body distorts, i.e., the classic example of the sphere of balls initially at rest that changes its shape to an elipsoid in the presence of gravity. So there seems to be a Weyl curvature there different from 0.
Also in Penrose's Road to reality book, he explains that the outward deflection of light rays outside the sun's rim is an example of the Weyl curvature.
What am I not getting right here?
When I read the first paragraph, I wasn't sure if it was right that FRW solutions were conformally flat, and the way I then convinced myself that they *were* was exactly by considering the WP explanation given in your second paragraph. If you put a ball in an FRW spacetime, there is no way that the ball can experience any tidal distortion into an ellipsoid. This follows from symmetry. If it distorted into an ellipsoid, then there would be preferred directions in space, e.g., the line containing the longest principal axis of the ellipse. But the FRW solutions are isotropic, so there can't be any such preferred direction.
But this example is in many texts on GR, normally they put the sphere of balls near the Earth and then release them, they become ellipsoid, and that explains the shapes of the sea tides too.
Maybe the problem is that these are not examples of Weyl curvature and the Ricci curvature also produces this shape effect that don't affect volume? I say it because I've just read that the Weyl curvature only happens in in empty spacetime, without any gravitational source nearby.
If this is the case I think that the wikipedia article and the paragraph from Penrose book are quite misleading.
There are definitely tidal forces in most FRW space-times, but they are spherically symmetric - and they're not due to the Weyl, they're due to the matter density, i.e. the Ricci.
If you consider the FRW basis the tidal forces are just a'' / a, where a(t) is the scale factor.
Technical details: the variabiles are t,chi,theta, and phi,
the basis one forms are:
[1,0,0,0], [0,a(t),0,0], [0,a(t)f(chi),0], [0,0,0,a(t)chi f(chi)sin(theta)]
a(t) is the time dependent scale factor for the expansion
f(chi) = chi, sin(chi), or sinh(chi) depending on if it's closed, flat, or open
and
[tex] R_{\hat{t}\hat{\chi}\hat{t}\hat{\chi}} = R_{\hat{t}\hat{\theta}\hat{t}\hat{\theta}} = R_{\hat{t}\hat{\phi}\hat{t}\hat{\phi}} = \frac{d^2 a}{dt^2} / a[/tex]The ideal FRW space-time is homogeneous, so the matter distribution is uniform, and it's not a vacuum solution. Without a cosmological constant, the acceleration is always negative, gravity serves to brake the expansion, and you get tidal compressive forces on a small rod, I think of them as being due to the matter and pressure (rho+3P) contained in a sphere co-located with the rod. With a cosmological constant, you might have an accelerating expansion, in which case the tidal forces tend to pull your rod apart.
and
Thanks, Pervect, I think I get it now. Probably what I took as meaning that tidal forces that don't affect volume are due to Weyl curvature, actually meant that Weyl curvature when present acts like tidal forces on shape.
What I need to understand better now is this, the Weyl tensor is explained as the curvature that equals the Riemannian curvature when there is no gravitational source (no Ricci curvature, vacccum solution-like).
Now, even in the vacuum solution the Riemannian curvature doesn't vanish (othervise we would be in flat Minkowski spacetime), and that would seem to lead to the Weyl curvature not vanishing, but as we have seen this seems not to be the case in conformally flat manifolds like ours. What am I not getting right?
I guess there's something I'm not understanding here, because I would have considered a vanishing Weyl tensor to be the definition of "no tidal forces," and yet I'm sure pervect is right, especially because another knowledgeable PF'er sent me a message telling me that my #2 was wrong.
The FLRW solution is not a vacuum solution, there is no empty space in this model, thus there is no Weyl curvature. Ricci curvature is of course also tidal (tidal effect is really nothing else than spacetime curvature), in that it usually is volume reducing. So a sphere of volume x can become < x due to Ricci curvature.
The way I think of it is that if you have the sphere of coffee grounds, matter outside the sphere will change its shape, but not the volume. This shape distortion can be ascribed to the Weyl curvature, though I don't recall the reference offhand. Matter inside the sphere will tend to cause the sphere to contract - Baez talks about this some in his tutorial paper "The meaning of Einstein's equation" http://math.ucr.edu/home/baez/einstein/ - and that's due to the Ricci.
But you said before that the tidal forces in FRW spacetimes are not due to the Weyl tensor but to the Ricci, since Weyl tensor vanishes in these conformally flat spacetimes.
So I'm still confused about the Riemann curvature in empty space that is supposed to be equal to the Weyl curvature in this setting. Is this right or not?
Hmm, so you would say there is Weyl curvature in Schwartzschild metric? The problem is that according to the definition of conformally flat manifolds, the spacetimes of constant sectional curvature like Schwartzschild are also conformally flat and therefore have a vanishing Weyl curvature.
Let's see if someone can clear up these confusions.
A supplement from the same site Pervect recommends: http://math.ucr.edu/home/baez/gr/ricci.weyl.html
(Maybe it will help to carefully track which statements are amdew about FRW versus Schwarzschild spacetimes.)
p413 of http://books.google.com/books?id=Si...schild+conformally+flat&source=gbs_navlinks_s says the interior Schwarzschild solution (ie. one which contains matter) is conformally flat. Do you think that might be what you're thinking of, instead of the vacuum Schwarzschild solution?
Perhaps in FRW it's no tidal distortion of shape (since Weyl is zero), but there is tidal distortion of volume (since Ricci is not zero)?
In contrast in Schwarzschild it's tidal distortion of shape (since Weyl is not zero), but no tidal distortion of volume (since Ricci is zero)?
All constant curvature and also all FRW metric spacetimes seem to be conformally flat which according to what I read implies a vanishing Weyl curvature. What I'm looking for is a way to reconcile this with tidal forces that only affect shape that are described by some as Weyl curvature and others as Ricci curvature, and I'm also trying to reconcile a not vanishing Riemann curvature in empty space and a vanishing Weyl curvature( for our type of spacetime) that in textbooks are equated.
Penrose is talking about the vacuum Schwarzschild solution, which as far as I understand has non-zero Weyl curvature.
The FRW solution with uniform matter only approximates our universe when stuff is averaged out over very large scales. Clearly, matter is not uniform in our solar system, it is bunched up into planets and sun, so on this smaller scale, the curved empty space outside our sun is approximated by the vacuum Schwarzschild solution (with mass parameter being the sun's mass). On an even smaller scale, the curved empty space outside the Earth is approximated by the vacuum Schwarzschild solution (with mass parameter being Earth's mass).
The "exact" solution describing our non-uniform universe must somehow contain corrections to all these approximations which must be joined up to each other somehow.
So how does this answer my questions? is deflection of light outward the sun's rim produced by Weyl curvature or Ricci's? if vacuum solutions have constant sectional curvature (they are static) so they have also vanishing Weyl curvature, how can they not have Riemann curvature vanishing if Weyl's and Riemann's are equal in vacuum?
The deflection of light around a star must be produced by Weyl curvature, since the light rays are traveling through the vacuum where there's no Ricci curvature.
Take the Schwarzschild solution for example. It's a vacuum solution, but does not have vanishing Weyl curvature. Why do you think a static solution necessarily has vanishing Weyl curvature ?
Schwarschild solution has constant sectional curvature (that of a parabole) so from wikipedia:
http://en.wikipedia.org/wiki/Conformally_flat_manifold
-Every manifold with constant sectional curvature is conformally flat.
-An n-dimensional pseudo-Riemannian manifold for n ≥ 4 is conformally flat if and only if the Weyl tensor vanishes.
All conformally flat vacuum solutions must be flat, so yes if they are flat then obviously the Weyl curvature tensor vanishes as well.
Two examples of a conformally flat spacetime are the FLRW and Schwarzschild interior solution. The Schwarzschild vacuum solution is not conformally flat. If wikipedia says differently then it is stated wrong.
I'm a bit rusty on relativity, and I'm not really familiar with the term "sectional curvature". Does it mean the curvature like in spaces of constant curvature (S3 etc) ? i.e. the manifold is characterised by the curvature scalar ?
If so, then Schwarzschild isn't like that.
Maybe you can find some spacelike 3-slices of the Schwarzschild solution that have constant intrinsic curvature, but that doesn't compeletely characterise the Riemann tensor of the spacetime. There is also the question of how the slices are embedded in the spacetime, which brings in the extrinsic curvature.
If you want to be sure though, sit down and compute the components of the Weyl tensor (approx 3 hours work, allowing for mistake time !)
Ah I see Passionflower has just responded. I should point out that my remarks pertain to the Schwarzschild vacuum solution (the one everybody knows and loves), not the interior solution
What you guys say make sense, maybe I'm mistaking constant sectional curvature with constant curvature, if these are indeed different, then Schwartzschild solution might not be conformally flat and wouldn't have Weyl tensor vanishing, that would solve some confusion for me.
Could someone confirm this?
It could be that you confuse it with conformally flat slices (e.g. 3D+1 composites). Certainly you can do that for the Schwarzschild metric, for instance the Painlevé–Gullstrand chart does just that.
You are right, I was confusing the spatial curvature(paraboloid) of the Schwarzschild metric that is indeed of constan sectional curvature, with the sectional curvature of the 4-spacetime manifold which is not.
Ok, so I understand that the vacuum solutions need not have vanishing Weyl curvature. And that makes sense because they have vanishing Ricci curvature but not vanishing Riemannian curvature, and the Weyl tensor is what you got when you remove Ricci curvature from Riemannian curvature. Hope I get it right this time.
So back to the tidal forces part, since the light deflection outside the sun is achieved with the vacuum solution too, it is indeed an expression of the Weyl tensor.
Perhaps it is a bit more complicated to assign the tidal effects to Ricci or Weyl curvature when speaking of timelike test particles since they are more mixed in this case.
Oops, I missed the link atty gave in post 10, it pretty much solves my doubts about this.
  • · Replies 19 ·
  • · Replies 30 ·
