Improve Text Scrolling: Fix Computer Issues
  • Thread starter Thread starter Monique
    Text
The discussion revolves around improving text scrolling on a computer after a Windows reinstallation. Participants explore potential causes for choppy scrolling, including hardware and driver issues, and suggest various troubleshooting steps.
  • One participant notes that staggered scrolling may be due to background processes consuming memory or CPU resources.
  • Another suggests checking the control panel for settings related to how many lines scroll per notch and recommends reinstalling mouse drivers if applicable.
  • A participant expresses uncertainty about checking scrolling settings and mentions that their CPU usage is low, indicating that it may not be the source of the problem.
  • Concerns are raised about missing device drivers, specifically for PCI FLASH Memory and a Video Controller, which may contribute to the scrolling issue.
  • Some participants discuss the absence of a mouse and suggest that the user may be using a trackpad, recommending adjustments to trackpad settings and driver installations.
  • One participant shares a personal experience of resolving similar issues by reinstalling video controller drivers, leading to improved performance.
  • Another participant mentions that rebooting their laptop has sometimes resolved jumpy scrolling issues.
Participants do not reach a consensus on the exact cause of the scrolling issue, with multiple competing views on potential solutions and troubleshooting steps remaining. Some participants agree on the importance of reinstalling drivers, while others focus on settings adjustments.
Participants mention various hardware configurations and driver dependencies, indicating that solutions may vary based on individual setups. There are unresolved questions about specific driver installations and settings adjustments.
Monique
Staff Emeritus
How do I improve text scrolling of my computer? It used to work fine, but I reinstalled windows and now when I scroll the text moves along in a staggered fasion, not smooth :(
Computer science news on Phys.org
I'm not sure that there's a simple answer to your question. You might want to check if something is running in the background. The staggering is likely to occur if the computer is running low on memory, or if something is eating a lot of cpu cycles.
Also, if you're running something like word, and the document you're opening is huge, you might have issues.
Go into your control panel and check to see how many lines one notch scrolls at a time.
You may also want to re-install the drivers if you have a special mouse (optical, wireless, usb, etc.)
How many lines a notch scrolls? How do I check that?
It's not my cpu, I'm using up only 1% of it and I've got a fast computer, even faster now that I've reinstalled windows.
I noticed some of my devices are not installed, one of them PCI FLASH Memory and a Video Controller... I guess I should try and get those working :-p
Well it depends on your mouse. Try this:
Click Start > Control Panel > Mouse. There should be a tab somewhere called "wheel" or similar.
You've just identified your problem! :approve: No video controller usually equals choppy frame rates, especially in Windows. Reinstall the drivers for your graphics adapter, and it should all be working nicely. I've had the same problem when reloading Windows and forgetting about my video card drivers.
I don't have a mouse :-p
You don't have a mouse, or you don't have 'mouse' in your control panel? :-p
Is there something in control panel called "input devices" or something like that? If there is, that should be the same as mouse.
Did you mouse come with any software drivers, usually on CD? If so, then install your mouse drivers. "Mouse" should be in your control panel now, or your should be able to find the software for your mouse in your start menu.
If you don't have any mouse drivers, check your mouse to see what type of mouse it is. Make sure you include all the details, eg "IntelliMouse Explorer 3.0A USB". Search google for the mouse drivers for your mouse, and then install them.
Andy
AMW Bonfire
Pointing devices vs computer mice
Monique does not have a mouse.
Monique does not have a mouse. She has a laptop and probably uses the trackpad to both control the pointer on the screen and to scroll (via the virtual vertical scroll strip on the right-hand portion of the pad).
Monique, it sounds like your drivers are messed up. A couple of things you can do are to
  • launch pointing device properties and fiddle with the settings;
    and,
  • install the latest drivers from the manufacturer.
The two most popular makers of trackpads are Alps and http://www.synaptics.com/support/index.cfm . You might have an icon for your pointing device in the lower right-hand corner of your screen. You should be able to right-click on that to get information about your device (and to get to utility windows that allow you to adjust various pointing device settings). Once you know the manufacter's name, you can download the latest device drivers from the appropriate link I put in this paragraph (Alps drivers seem to be hard to find, so I linked to a google search).
Also, I have sometimes had problems with jumpy scrolling (I use a laptop also) that solved themselves with a simple reboot (I normally don't ever shut my computer down; I hibernate it instead).
WhOOHOO! I reinstalled the video controller and now it's fast & smooth :biggrin: :approve:
  • · Replies 21 ·
  • · Replies 17 ·
9K
