Solve x in Periodic Continued Fraction Expansion
  • Thread starter Thread starter *FaerieLight*
    Fractions
The problem involves finding a real positive number x represented by a periodic continued fraction expansion of the form [0;a,b,a,b,...], where a and b are positive integers. The discussion centers around the interpretation and manipulation of this continued fraction.
  • Participants discuss the notation of the continued fraction and its implications, with some suggesting that it can be expressed in terms of a quadratic equation. Others explore the properties of continued fractions and how to manipulate them to derive equations involving x.
The discussion is active, with participants providing insights into the structure of the continued fraction and its relationship to quadratic equations. Some have shared their attempts to identify patterns in continued fractions related to square roots, indicating a productive exploration of the topic.
There are references to specific forms of continued fractions and their characteristics, as well as a mention of previous experiences with similar problems. Participants are also considering the complexity of the equations derived from the continued fraction manipulations.
*FaerieLight*
Find the real positive number x with periodic continued fraction expansion [0;a,b,a,b,...] where a and b are positive integers.
I have determined that x definitely involves a root.
It's been a while since I have done these kinds of problems but I think the notation "[0;a,b,a,b,...]" means a continued fraction of the form
[tex]x= \frac{a}{b+ \frac{a}{b+ \frac{a}{b+\cdot\cdot\cdot}}}[/tex]
If that is correct, then that is the same as
[tex]x= \frac{a}{b+ x}[/tex]
since the "continued" fraction in the denominator is still just "x".
Of course, that is the same as the quadratic equation [itex]x(b+ x)= x^2+ bx= a[/itex] or [itex]x^2+ bx- a= 0[/itex]. Use the quadratic formula to solve that.
If [tex]\alpha=[0;a,b,a,b,...][/tex], what do you get by computing
[tex]\frac{1}{\alpha} -a?[/tex]
Basically you want to continue performing operations on [tex]\alpha[/tex] until you get [tex]\alpha[/tex] back. The resulting equation will always be quadratic.
Edit: HallsofIvy, not quite, the continued fractions in the [tex][a_0;a_1,\ldots][/tex] notation are the so-called simple continued fractions, which always have unit numerators. So
[tex][0;a,b,a,b,...] = 0 + \frac{1}{a+\frac{1}{b+\frac{1}{a+\cdots}}}[/tex]
Your method still works for this of course, the result is just a bit more complicated.
Thanks HallsofIvy!
I was taught that [0;a,b,a,b,a,...] denotes
[tex]\frac{1}{a+\frac{1}{b+\frac{1}{a+...}}}[/tex]
The quadratic then becomes ax2+abx-b=0
Thank you very much! I actually looked at the continued fractions expansions for [tex]\sqrt{n}[/tex] for n=1,2,3,...,20 and tried to find patterns. I did find some interesting ones, but I just couldn't manage to use them to work out this problem. I suspected the solution was a simple one, and indeed thank you very much for showing me this beautifully simple solution.
Thanks to you too, fzero!
