How Do You Calculate Elevator Cable Forces for Maximum and Minimum Motor Load?
The maximum force that the motor should exert on the supporting cable of an elevator with a mass of 4100 kg and a maximum acceleration of 0.0700g is calculated to be approximately 43 kN. This value is derived from the sum of the gravitational force (40180 N) and the force required for acceleration (2815.47 N). Conversely, the minimum force required is approximately 37 kN, calculated by subtracting the force needed for deceleration from the gravitational force. These calculations utilize Newton's Second Law and assume ideal conditions without accounting for friction or air resistance.
  • Understanding of Newton's Second Law of Motion
  • Basic knowledge of force calculations (F=ma)
  • Familiarity with gravitational force calculations (Fg = mg)
  • Concept of acceleration in physics
  • Study the effects of friction and air resistance on elevator systems
  • Learn about safety factors in elevator design
  • Explore advanced dynamics of multi-stage elevator systems
  • Research the impact of load variations on motor force requirements
Mechanical engineers, elevator design professionals, physics students, and anyone involved in the design and analysis of elevator systems will benefit from this discussion.
lmf22
An elevator (mass 4100 kg) is to be designed so that the maximum acceleration is 0.0700g.
What is the maximum force the motor should exert on the supporting cable?
What is the minimum force the motor should exert on the supporting cable?
I converted the acceleration to .6867 m/s^2 and plugged that and the mass into F=ma, but the answers doesn't seem to be right.
Upward direction positive; downward direction negative
[tex]\begin{array}{cc}<br /> Newton's\ 2nd\ Law\\<br /> \sum \vec{F}=m\vec{a}\\<br /> F_{ec} + W =ma \ with \ a= \ The \ elevator's\ acceleration\\<br /> F_{ec} + (-mg) = ma\\ <br /> F_{ec} = m(a+g)\\<br /> F_{ec_max}= m(0.0700g+g)\ When\ a=+0.0700g\ ie\ The\ elevator \ accelerates\ upward\\<br /> F_{ec_min}= m(-0.0700g+g)\ When\ a=-0.0700g\ ie\ The\ elevator \ accelerates\ downward\\<br /> \end{array}[/tex]
The maximum force that the motor should exert on the supporting cable would be equal to the weight of the elevator plus the force needed to accelerate it. The weight of the elevator can be calculated using the formula Fg = mg, where m is the mass of the elevator and g is the acceleration due to gravity (9.8 m/s^2). So, Fg = (4100 kg)(9.8 m/s^2) = 40180 N.
To find the force needed to accelerate the elevator, we can use the formula F = ma, where m is the mass of the elevator and a is the acceleration (0.6867 m/s^2). So, F = (4100 kg)(0.6867 m/s^2) = 2815.47 N.
Therefore, the maximum force the motor should exert on the supporting cable would be 40180 N + 2815.47 N = 42995.47 N or approximately 43 kN.
The minimum force that the motor should exert on the supporting cable would be equal to the weight of the elevator minus the force needed to decelerate it. So, the minimum force would be 40180 N - 2815.47 N = 37364.53 N or approximately 37 kN.
It is important to note that these calculations assume ideal conditions and do not take into account factors such as friction and air resistance, which may affect the actual forces needed to accelerate and decelerate the elevator.
  • · Replies 31 ·
  • · Replies 19 ·
  • · Replies 33 ·
