Does Time Exist for a Photon Traveling from Point A to Point B?
  • Context: Graduate
  • Thread starter Thread starter kernelpenguin
The discussion centers around the concept of time from the perspective of a photon traveling from one point to another. Participants explore theoretical implications of special relativity, the nature of time, and the relationship between speed and time perception, with a focus on whether time exists for a photon during its travel.
  • Some participants suggest that from a photon's point of view, no time passes at all during its travel from point A to point B.
  • Others argue that while photons do not experience time, the concept of time may still be relevant for other entities that can measure it.
  • A participant notes that proper time for a photon is defined as zero, implying that it does not experience space or time in the same way as slower-moving observers.
  • Some contributions highlight the distinction between special relativity (SR) and quantum electrodynamics (QED), suggesting that the classical understanding of a photon's path may not apply in quantum contexts.
  • There is a discussion about the implications of the Planck time and whether it is the smallest unit of time, with some participants questioning this assumption based on the nature of a photon's experience.
  • One participant emphasizes that the speed of light being constant for all observers is foundational to the theory of relativity, while also noting that photons exist outside the formalism of relativity.
Participants express multiple competing views regarding the nature of time for a photon, with no consensus reached on whether time exists for a photon or the implications of this for concepts like the Planck time.
There are unresolved questions about the relationship between special relativity and quantum theories, particularly regarding the measurement of time and the implications of a photon's experience of time and space.
kernelpenguin
1. Time seems to have a 'smallest step' -- the Planck time unit.
2. A photon travels at c.
3. When you get closer to c, time dilates causing your passage in time to get slower compared to the rest frame.
And now...
If a photon is emitted at point A and absorbed at point B, then from the point of view of that photon, how much time has passed? An eternity? None at all? It all happened at the same time?
This one's been bugging me for a long time now.
From the photon's point of view? I'd have to say no time at all. From a photon's point of view time might as well not exist.
A photon does not experience the passage of time, from the moment it is created to the moment it is absorbed/destroyed.
FYI, item (1) on your list is hypothetical - no one knows what happens at the Plank scale. However, that doesn't change anything. Items (2) and (3), as well as the consequence that photons don't experience time, remain valid.
If you travel in your rocket at speed near c, than you would experience time as going normal. However, when an observer outside the rocket looks at your clock in the rocket, time is going slower. So if you're a photon traveling at c, time passes by normally. The photon "experiences" the passage of a year when traveling the distance of a lightyear. The observer, on the outside looking at the clock of the photon, sees time standing still.
This is incorrect. The photon sees neither distance (all space is Lorentz contracted to zero length) nor time. Formally, this is because proper time is defined as
[tex]\tau = - \int_{x_1}^{x_2} ds[/tex]
The integral is to be carried out over the path in spacetime. On paths traveled by light, this is always zero. Informally, suppose the photon could somehow keep track of time. We may ask "how long until an external observer measures any change in the photon's clock". Since that observer measures time as standing still for the photon, he concludes the clock never advances. Otherwise, there would be a contradiction within SR.
The [tex]-[/tex] sign corresponds to [tex](-,+,+,+)[/tex] metric.
I just wanted to clarify a possible dummy source of confusion.
But if a photon is created and absorbed without any time passing for it in between, would it not demonstrate that the Planck time is not the smallest unit of time possible?
The fact that a photon is incapable of measuring any finite time doesn't mean that time may not be quantized for something that actually can measure time.
Actually, ds=o for the photon at all times. This is said to imply that it experiences space and time equally.
You can't really use any of the formulas for SR on the photon except for ds=0. It stands outside of the relativity formulation since its velocity is the same for all observers.
juju
Is this the worst misunderstanding possible !? The photon constant speed is the basis for a need of SR. It is the fundamental observation that there is a maximum speed that requires us to quit the simple world of Galilean relativity.
Yes, c is the basis of relativity because it is the same for all observers, but stands outside the formalism. c is the least upper bound for the velocity but the interval is open, not closed. Gamma goes to infinity for v=c.
juju
kernelpenguin: Your confusion might result from the fact that you're considering SR and QED (or just quantum ideas in general) simultaneously. QED doesn't actually have a 'Planck Time', it's a number that's come out of broader (but less complete) unification theories, and incidently, gets put in a lot of popular science books. Recall that in QED, photons travel all paths, and to find out the probability of it getting from A to B you add up the probabilities of it traveling along every path, and the 'expected' path (if you really want one) looks like the classical straight line between two points. Thus the notion of a photon's path (in spacetime, not just space) isn't really valid in the first place and it's a whole different kettle of fish to be asking what the hell is going on.
The 'classical' SR result is that light travels along paths of no 'proper' length in time or space - this of course might change if someone comes up with a self-consistent and usable theory of quantum gravity.
Kane
  • · Replies 21 ·
  • · Replies 16 ·
  • · Replies 23 ·
  • · Replies 29 ·
  • · Replies 58 ·
  • · Replies 46 ·
  • · Replies 71 ·
