What is the operator between A A^ in A vec = A A^
  • Context: Graduate
  • Thread starter Thread starter ManishR
    Operator
The discussion revolves around the mathematical expression involving a vector A and its directional counterpart A dir (denoted as A with a hat). Participants explore the nature of the operator between A and A dir, questioning whether it represents multiplication and how to differentiate A in terms of A and A dir. The scope includes mathematical reasoning and conceptual clarification regarding vector differentiation.
  • Some participants propose that the operator between A and A dir is multiplication, questioning the reasoning behind this assumption.
  • Others clarify that A represents a vector, while A dir is a unit vector in the same direction as A, leading to confusion about the differentiation process.
  • A participant expresses that they have solved the differentiation of A and seeks a different approach, but does not specify their own method.
  • Another participant challenges the clarity of the problem, asking for specifics on what the differentiation is with respect to and the context of the curve involved.
  • There is a discussion about the implications of A being dependent or independent of a variable x, with one participant stating that if A does not depend on x, its derivative would be zero.
  • Concerns are raised about the definition of the operator if it is not multiplication, prompting a request for clarification on what the operator could be.
  • One participant emphasizes the importance of correctly defining the derivative and mentions the product rule for derivatives, suggesting that it remains applicable in this context.
Participants express differing views on the nature of the operator between A and A dir, with no consensus reached on whether it is multiplication or something else. The discussion remains unresolved regarding the differentiation of A and the specifics of the problem context.
There are limitations in the clarity of the problem statement, particularly regarding the definitions of A and A dir, the context of differentiation, and the assumptions about the dependency of A on variable x.
ManishR
consider a vector A
A = A(A dir)
here A dir is A with hat on it. i don't how to do that with LATEX.
is the operator between A and A dir is multiplication . if yes then why?
could anybody please derive the differentiation of A in terms of A and A dir?
What does "A with a hat on it" mean? What is the difference between A and A?
A is a vector .
A is magnitude of vector A
A dir or "A with a hat on it" is vector whose magnitude is 1 and direction is equal to direction of A
i've solved and understood "the differentiation of A" , so no need to re-solve it, but i won't mind if u can provide some different approach.
Let's see...you have solved the problem and don't want us to re-solve it. You want us to show you a different approach, but you haven't told us your approach. And the problem doesn't really make sense. Differentiate with respect to what? You're going to have to be more specific.
Hit the quote button to see how I'm doing the LaTeX. (Note that there's a bug that makes the wrong images show up in previews most of the time. The workaround is to refresh and resend after each preview).
[tex]\mathbf A=A\hat A[/tex]
Is the problem to start with [tex]\vec r=r\hat r[/tex] and differentiate with respect to time? Is this a curve in [tex]\mathbb R^2[/tex] or [tex]\mathbb R^3[/tex]?
i don't want u to show me a different approach (ofcourse then i would need to provide u my approach which is rather a intuitional approach). what i meant by that is u can resolve it with an approach and if that approach is different than mine then i will be glad.
"differentiation of A" means differentiation of A with respect to x (let say) then
either (A depends on x) or (A does not depend on x)
if (A does not depend on x) then
[tex]\frac{d\textbf{A}}{dx} = 0[/tex]
it will always be zero whatever the operator is.
which ofcourse i am not asking.
what i was (or am) asking is
[tex]\frac{d\textbf{A}}{dx} = ?[/tex]
when [tex]\textbf{A} = \textbf{A}(x)[/tex],
what will be
when the operator between [tex]A[/tex] and [tex]\hat A[/tex] is not multiplication
If it's not multiplication, then you would have to specify what it is. But why wouldn't it be? Isn't your [tex]\mathbf{\hat A}[/tex] defined by
[tex]\mathbf A=|A|\frac{\mathbf A}{|A|}=|A|\mathbf{\hat A}\ \text{?}[/tex]
I don't recommend using the expression A=A(x) to say "A is a function and we use the symbol x for its argument", because it looks like you're setting a function equal a number. (A(x) is a number in the range of the function A).
The derivative is defined as always
[tex]\frac{dA(x)}{dx}=\lim_{h\rightarrow 0}\frac{\mathbf{A}(x+h)-\mathbf{A}(x)}{h}[/tex]
and the product rule for derivatives still holds: (fg)'(x)=f'(x)g(x)+f(x)g'(x)
  • · Replies 36 ·
  • · Replies 19 ·
  • · Replies 26 ·
  • · Replies 59 ·
