Random thought about force and motion
  • Context: Undergrad
  • Thread starter Thread starter tadpole
    Force Motion Random
The discussion revolves around the concepts of force, motion, and the behavior of a bullet fired in space. Participants explore various scenarios and questions related to acceleration, force, momentum, and energy, particularly in the context of a bullet's motion after being fired from a gun.
  • One participant questions the assertion that the push force is zero when an object is moving horizontally, suggesting that a force is needed to overcome friction.
  • Another participant states that a bullet does not accelerate after leaving the gun and that if the net force is zero, it will continue moving at constant speed.
  • There is a discussion about whether a bullet has force after it leaves the gun, with one participant asserting that it has momentum and energy instead.
  • One participant proposes that energy converts back to force upon impact, while another clarifies that force and energy are distinct and do not convert into one another.
  • Questions arise regarding what causes damage upon impact, with a focus on momentum rather than energy conversion.
  • Another participant points out that forces are generated upon contact and questions the nature of forces acting on the bullet while the gun is fired.
  • Concerns are raised about the specificity of the scenario regarding gravity in space, with one participant suggesting that gravity should be disregarded for clarity.
Participants express differing views on the relationship between force, momentum, and energy, with no consensus reached on the nature of these concepts in the context of a bullet fired in space. The discussion remains unresolved regarding the specifics of forces acting on the bullet and the implications of gravity.
Participants highlight the need for clarity regarding the assumptions made about the environment in space, particularly concerning gravity and friction. There is also ambiguity in the definitions and relationships between force, momentum, and energy.
tadpole
It has been awhile since I took Physics. The other day my daughter asked some questions about force. She told her teacher explained if the object is moving horizontal the push force is 0. I said that can't be right. There has to be a force to overcome friction. This lead me thinking about other scenarios. Some of these questions are kind of silly. I hope some of you can enlighten me. Thanks for taking the time to answer my random thought.
If you shoot a gun in space, after the bullet left the gun:
a) does it accelerate ?
b) if yes, what cause it to accelerate since there is no propulsion or any kind of power to change velocity ? Does it continue to accelerate or at some point it will reach a constant velocity ?
c) if it reach a constant velocity, than does that mean the bullet no longer have force since
F = M X A. If the force is 0, than when the bullet hit me, it would not hurt, right ? :))
d) does it decelerate ? what cause it to decelerate ?
No.
A moving bullet doesn't 'have force'--it has momentum and energy. A force is an interaction between objects. When the bullet hits you, you and the bullet will exert forces on each other.
If the net force on an object is zero, then it will keep moving at constant speed in a straight line. Presumably there's no force acting on the bullet after it leaves the gun.
So even though the bullet does not have any force, it has momentum and energy and when it hits another object, this energy somehow converts pack to force at impact. Thanks, I am glad you told me, I was going to jump in front of the bullet to prove an experiment.
Force and energy are different things. One doesn't convert into the other.
Ok, so what cause the damage if not some energy conversion, is it the momentum ? I know I heard on TV, they always say something hit something with a force of blah. I never heard they said impact with momentum of blah or energy of blah. Don't give me up on yet.
There's nothing wrong with saying something hits something else with some force. That doesn't mean that the something was 'carrying' the force around with it. Forces between objects are generated upon contact.
Yes, so -question to tadpole - what forces are in play while the gun is being fired? (assuming you can somehow get gunpowder to ignite in outer space) How long (how much time) does the force act on the bullet? And also, how do you know in general when you have a force? Could you think of another scenario where you need to identify the forces acting? You mentioned friction...
I don't think "space" is specific enough, since most space missions are close to the Earth where everything is constantly being accelerated by gravity.
Hell, even 10 universes away there's still gravity, so the bullet will always be accelerated. That's probably not the intent of the problem, but imo it should at least be specified to disregard gravity, just like we usually specify to disregard friction.
I don't think gunpowder needs air to burn.
  • · Replies 22 ·
  • · Replies 114 ·
  • · Replies 29 ·
  • · Replies 37 ·
