Potential of uniformly charged disk off axis
The discussion revolves around calculating the potential of a uniformly charged disk off-axis, specifically using the framework provided in Griffiths' textbook. The original poster is tasked with deriving the first three terms of the potential function based on a given boundary condition and the general solution for Laplace's equation in spherical coordinates.
  • The original poster attempts to rewrite the potential in terms of a new variable and perform a Taylor series expansion, but is uncertain about the appropriate point of expansion. They question whether to expand about u=0 or u=1, noting that different expansions yield different results.
  • Some participants suggest that expanding about u=0 would provide terms in powers of u, while others express concern about the complexity of expanding around u=1 and the implications for determining coefficients in the series.
Participants are actively exploring different expansion methods and their implications on the results. There is recognition of the challenges posed by the differing outcomes of the expansions, and some guidance has been offered regarding the Taylor series approach. However, there is no clear consensus on the best method to proceed.
The original poster is working under the assumption that r is greater than R, and they are navigating the complexities of Taylor series expansions in the context of the problem's requirements. There is an acknowledgment of the potential for approximations and the need for clarity on the expansion point.
finalnothing
As per Griffiths 3.21, I am given the on axis potential a distance r from a uniformly charged disk of radius R as a function of [tex]\sigma[/tex]. Using this and the general solution for laplace's equation in spherical coordinates with azimuthal symmetry, calculate the first three terms in the general solution. Assume [tex]r>R[/tex].
[tex]V(r,\theta)=\sum^\infty_{l=0}{(A_lr^l +\frac{B_l}{r^{l+1}})P_l(\cos\theta)}[/tex]
[tex]V(r,0)=\frac{\sigma}{2\epsilon_0}(\sqrt{r^2+R^2}-r)[/tex]
As I know that V goes to 0 at infinity, all the A terms must be 0. Applying the boundary condition V(r, 0) and nothing that [tex]P_l(1)=1[/tex] leaves me with
[tex]V(r,0)=\sum^\infty_{l=0}{\frac{B_l}{r^{l+1}}}[/tex]
Now, my major idea was to rewrite V(r, 0) in terms of [tex]u=\frac{R}{r}[/tex] and then perform a taylor series expansion in terms of u. This will generate successive terms of the form [tex]\frac{C_l}{r^{l+1}}[/tex], then I simply assign my B variables equal to the C variables. However, I hit a moderate snag that I was not able to reason out. What point should I expand my taylor series about? Should I expand it about u=0 (r >> R) or about u=1 (r=R)? Or should I take the average of the two expansions? Each expansion does give different C values, when the problem expressed suggests this should not be the case. Am I simply going in the wrong direction or does this problem expect an approximate answer? Any help would be much appreciated.
If you Taylor expand a function [itex]f(u)[/itex] about the point [itex]u=u_0[/itex], you get terms in powers of [itex](u-u_0)[/itex]. So, if you want terms in powers of [itex]u[/itex], you expand about [itex]u=0[/itex].
Thanks for your reply. However that is something I already considered. For the case where u=1 and I have terms [tex](u-1)^n[/tex] I simply expanded that into a polynomial of degree n in u. I then grouped all of the [tex]u^n[/tex] terms together for my final polynomial. Here are the equations and results I have.
[tex]V(u)=\frac{u\sigma}{2\epsilon_0R}(\sqrt{1+u^2} - 1)[/tex] where [tex]u=\frac{R}{r}[/tex]
I expand to the fourth term of the taylor series. Expanding about point u = 0 gives
[tex]V(r, 0)=\frac{u^3\sigma}{4\epsilon_0R}[/tex] as most of the terms in the derivatives of V are a product with u. However, when I expand about u=1 I get (for 3 terms, really messy)
[tex]V(r, 0)=\frac{\sigma}{2\epsilon_0R}(\frac{3\sqrt{2}}{4}-(1+\sqrt{2})u+\frac{5\sqrt{2}}{4}u^2)[/tex]
This is starting to get really messy. However, the difference in approximations is quite drastic since nearly all terms of V(u) are product of u and thus disappear in the u=0 approximation but remain in the u=1 approximation. At this point I'm not sure if expanding V(r, 0) in terms of [tex]r^{-l}[/tex] is the correct response. If anyone has any suggestions on another route to take this problem that would be great.
//note, preview is showing latex images for my previous post, not sure if my tex is correct
That's fine, in theory. However in order to find the coefficient of say [itex]u^2[/itex] in that manner, you'd have to expand out every term in the infinite Taylor series (terms like [itex](u-1)^{677}[/itex] will contain multiples of every power of [itex]u[/itex] from 1 to 677, including [itex]u^2[/itex]... You would quite literally be calculating coefficients for eternity.
  • · Replies 16 ·
