Isobaric heating to find volume and temperature
The discussion focuses on the isobaric heating of 2 kg of water initially at 250°C, converting it from a saturated liquid to a saturated vapor. The initial specific volume (v_f) is identified as 0.001252 m³/kg at a pressure of 3976.2 kPa. To find the final temperature and specific volume (v_g) of the saturated vapor, the use of thermodynamic tables and interpolation is essential. The final temperature will increase as the water transitions to vapor, confirming that the process is not isothermal.
  • Understanding of thermodynamic tables for water properties
  • Knowledge of isobaric processes in thermodynamics
  • Familiarity with specific volume calculations
  • Basic concepts of latent heat and phase transitions
  • Study the use of thermodynamic tables for saturated liquids and vapors
  • Learn about isobaric heating processes in detail
  • Explore interpolation techniques for thermodynamic properties
  • Investigate the concept of latent heat and its implications in phase changes
Students and professionals in thermodynamics, mechanical engineers, and anyone involved in heat transfer and phase change processes.
marcas3
Initially, 2 kg of water is at 250 Celsius and it exists as a saturated liquid. It is now isobarically heated until all of it is converted to saturated vapor. Find final temperature and volume.
Thermodynamic tables and the use of interpolation.
Since the process is isobaric, it is heated at a constant pressure. Next, using thermodynamic tables, the specific volume of the saturated liquid (v_f) is .001252 m^3/kg and the initial pressure is 3976.2 kPa at 250 Celsius. To find actual initial volume we just divide the specific volume by the mass (2 kg).
Trouble I am having is finding the final temperature and final specific volume (now I am looking for v_g since the water now exists as a saturated vapor). I thought about using the pressure table to find v_g and temperature but this doesn't make sense to me because then it seems the final temperature would be the same as the initial temperature, which I don't think is possible since this process is not isothermal. Please help.
As long as there is water present (and pressure is constant) process is also isothermic - temperature will go up once there will be no water to boil up and consume added heat.
Name 'latent heat' didn't came from nowhere.
  • · Replies 81 ·
