| Thread Closed |
Relative dielectric constant - More than one dielectric in a capacitor |
Share Thread | Thread Tools |
| Oct6-10, 11:23 AM | #1 |
A parallel plane capacitor with conducting plates area [tex]\Sigma[/tex]= 400cm2, distant d=5mm, is half filled of mica (k1=5) and half filled of paraffin (k2=2). Calculate: a) C (Capacitance of the capacitor) ...others 2. Relevant equations None 3. The attempt at a solution I haven't got too many problems solving this exercise but i just don't know how to get to the correct result of k (relative dielectric constant) when there's more than one dielectric in a parallel plate capacitor.
| Oct6-10, 02:20 PM | #2 |
Calculate the voltage drop across the two dielectrics separately. Their sum will equal the voltage drop across the capacitor.
| Oct7-10, 03:05 AM | #3 |
Ok, then:
V=(E*d)/k ; V1=(E*(d/2))/k1; V2=(E*(d/2))/k2; V=V1+V2; (E*d)/k=((E*d)*(k1+k2))/(2k1k2) k=(2k1k2)/(k1+k2) this should be correct thanks. ------------------------------------------------------- Another question: if i would have had a capacitor like this: ![]() i can't find k like i did before 'cause k would be like (k1*k2)/k1+k2 while it should be like (k1+k2)/2 |
| Oct7-10, 05:03 AM | #4 |
You can think of it as two capacitors in parallel.
| Oct7-10, 06:50 AM | #5 |
ok, thanks i got it now, the sum of the capacitances of the two capacitors (cause they are in parallel) gives me the total capacitance.
So, in the first exercise i've asked you, the capacitors can be considered as connected in series? |
| Oct7-10, 07:40 AM | #6 |
Yes, effectively it's two capacitors in series.
| Oct7-10, 07:40 AM | #7 |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Relative dielectric constant - More than one dielectric in a capacitor
| Point charge inside Dielectric Sphere embedded in Dielectric Slab | Advanced Physics Homework | 4 | ||
| what is the dielectric constant of the slab on a parallel plate capacitor ? | Introductory Physics Homework | 5 | ||
| capacitor with dielectric | Introductory Physics Homework | 12 | ||
| Cyber forum of Dielectric Phenomena or of Dielectric and Electrical Material? | General Physics | 0 | ||
| [SOLVED] Cyber forum of Dielectric Phenomena or of Dielectric and Electrical Material | General Physics | 0 | ||
