Calculating Water Needed for 0.1M and 0.12M Hydrochloric Acid
  • Thread starter Thread starter josephcollins
    Acid
The discussion focuses on calculating the amount of water needed to dilute a 0.123 M hydrochloric acid (HCl) solution to concentrations of 0.1 M and 0.12 M. To achieve a 0.1 M solution, 230 milliliters of water must be added to 1 liter of the original solution. For a 0.12 M solution, 25 milliliters of water is required. These calculations are based on the principle of dilution and the formula C1V1 = C2V2.
  • Understanding of molarity and dilution principles
  • Familiarity with the formula C1V1 = C2V2
  • Basic knowledge of hydrochloric acid properties
  • Ability to perform unit conversions (liters to milliliters)
  • Study the concept of molarity in detail
  • Learn about titration techniques and their applications
  • Explore the properties and uses of hydrochloric acid in laboratory settings
  • Investigate other dilution calculations for different concentrations
Chemistry students, laboratory technicians, and anyone involved in chemical solution preparation and dilution calculations.
josephcollins
Could someone please give me a hand with this:
A solution of hydrochloric acid was standardised by titration and found to be 0.123 M. How much water must be added to 1dm3 of this solution to make it exactly:
a. 0.1M and b. 0.12M ?
Thanks ppl
Chemistry news on Phys.org
Hello,
One liter of 0,123 M HCl means 0,123 mole of HCl is present in the solution. So if you want a) 0,1 M, you'll need to add: 0,1=(0,123/V)=1,23; and therefore 230 milliliters.
b) A 0,12 M of HCl solution from 0,123 M solution is prepared by adding: 0,12=0,123/V=1,025; and therefore, 25 milliliters of water.
Please note that you already have 1000 milliliters of solution, so the resulting new volume indicates the amount added, starting from 1000 milliliters.
Regards, chem_tr
  • · Replies 21 ·
