Finding a and b in an infinite series limit comparison test
The discussion revolves around identifying the sequences "a_n" and "b_n" in the context of applying the Limit Comparison Test to the infinite series \(\sum_{n=1}^\infty \frac{\sqrt{n+2}}{2n^2+n+1}\). Participants explore how to determine appropriate comparisons for convergence analysis.
  • Participants discuss the identification of "a_n" as the original function and question how to derive "b_n". There are attempts to understand the reasoning behind approximating terms for large \(n\) and whether a general method exists for finding "b_n".
The discussion is ongoing, with participants sharing insights about approximating terms for large \(n\) and the implications of dropping lower degree terms. Some express uncertainty about the terminology and concepts involved, while others provide clarifications regarding the nature of polynomial dominance in limits.
Participants note the importance of understanding the behavior of terms as \(n\) approaches infinity, emphasizing that the dominant term dictates the comparison for the Limit Comparison Test. There is also mention of the need for clarity in distinguishing between methods and equations in this context.
MillerGenuine
Finding "a" and "b" in an infinite series limit comparison test
[tex] \sum_{n=1}^\infty \frac{\sqrt{n+2}}{2n^2+n+1}[/tex]
How do I identify my a_n and my b_n?
In this particular problem you need to use the Limit comparison test which is your "a_n" divided by your "b_n". I know how to solve the problem once these variables are identified, but for each question i attempt to do, i am not seeing a pattern in how to identify your a and b.
You can show that the term of this sum is smaller than:
1/( n sqrt(n+2))
which is in return smaller than 1/(n sqrt n)
and if I recall correctly the sum of 1/n^a converges for a>1.
for this problem they get
[tex] a_n= \frac{\sqrt(n+2)}{2n^2+n+1}<br /> b_n= \frac{1}{n^(3/2)}[/tex]
how are these values obtained?
I realize a_n is just the initial function..but how did they get b_n?
I know to divide them, & i know how to get the answer from this point, i just have no idea how they got their "b_n" value
For large n, [itex]\sqrt{n + 2} \approx \sqrt{n}[/itex], and [itex]2n^2 + n + 1 \approx 2n^2[/itex], so the whole expression can be compared to 1/(2n3/2), which is close to what MathematicalPhysicist said.
Is there some kind of equation to find b_n?
Im not sure the terminology of "large n". why can you approximate n+2 to be just n, and 2n^2 + n + 1 to be just 2n^2. ?
If you're looking for some formula that you can use instead of thinking, no, there isn't. "Large n" simply means in the limit as n goes to infinity.
For n + 2:
If n = 10, n + 2 = 12
If n = 100, n + 2 = 102
If n = 1000, n + 2 = 1002
The larger n gets, the closer n and n + 2 are, relatively speaking. The difference is always 2, but the relative difference gets smaller and smaller.
In a polynomial in n, the dominant term when n is large is the term of highest degree. That's why I can say that n + 2 [itex]\approx[/itex] n, for large n, hence their square roots are approximately equal as well.
That's also why I can say that for large n, 2n2 + n + 1 is about equal to 2n2. The larger n is, the smaller the effect of the lower degree terms.
So would it be safe to say that for any problem where i must find my b_n, such as the one above, i essentially take the term with the highest degree (in the numerator and denom) and drop the rest? because n becomes so large as it approaches infinity the rest of the polynomial is negligible?
When i had said "equation" in my previous post i meant a method to always find b_n. like i asked in the above post, taking the term with highest degree and dropping the rest.
If you're dealing with a series whose general term is a rational function, yes.
You understand of course that an equation and a method are completely different things?
Of course. I wasnt sure quite how to word my question so I had to make a stretch. I tend to miss the smallest details (such as this b_n issue) yet can understand everything else magnificently. Go figure. I appreciate the help though, it makes much more sense.
