X-ray diffraction for 2-D crystal
X-ray diffraction is indeed applicable to 2-D crystals such as Graphene. The Bragg interference criteria in this context involves rods in reciprocal space that are perpendicular to the 2-D plane. Bragg peaks manifest at the intersection of the Ewald sphere with these rods. When the incident beam is directed perpendicularly to the surface, backward scattering reveals (hk) reflections at specific 2theta angles less than 180 degrees, which vary based on the vertical position of the detector.
  • Understanding of X-ray diffraction principles
  • Familiarity with reciprocal space concepts
  • Knowledge of Bragg's law and its application
  • Experience with 2-D crystal structures, particularly Graphene
  • Research the application of Bragg's law in 2-D materials
  • Explore the construction and interpretation of the Ewald sphere
  • Learn about the specific diffraction techniques for Graphene
  • Investigate the role of detector positioning in X-ray diffraction experiments
Materials scientists, physicists, and researchers involved in crystallography and the study of 2-D materials will benefit from this discussion.
Useful nucleus
Is it possible to perform x-ray diffraction for 2-D crystal like Graphene? If poossible how does the bragg interference criteria look like here?
Yes it is possible. In the reciprocal space you will have rods perpendicular to the 2D-plain. Your Bragg peaks will a appear at the intersection of the Ewald sphere with the rods. For instance if you direct the incident beam perpendicular to the surface and detect the backward scattering you will detect (hk) reflections at some 2theta angles < 180. The angle will depend on vertical detector position in this case.
  • · Replies 17 ·
