| Thread Closed |
Devices that can inject air-fuel mixture into the combustion chamber |
Share Thread | Thread Tools |
| Oct7-10, 08:52 AM | #1 |
hey,
I need all the help i can get on this one....... can u guys tell me if there is any device that can be used instead of an ordinary fuel injector since i want it to be able to inject an air-fuel mixture. since the normal injector cant inject air i desperately need another device. please do help!!!! |
| Oct7-10, 09:15 AM | #2 |
Pretty hard to inject fuel and air at the same time considering the large volume of air needed by the engine. What's wrong with using a conventional intake stroke? That's exactly what it does and it seems to work very, very well!
| Oct9-10, 10:30 AM | #3 |
| Oct10-10, 02:47 PM | #4 |
Some gas engines use port injection; these injectors should be able to cope with air with fuel in suspension. For use in-cylinder you are going to struggle if you're planning to use 'conventional' cylinder pressures.
| Oct10-10, 10:32 PM | #5 |
Do you have any examples of the injectors that you're thinking of, brewnog?
| Oct11-10, 02:53 PM | #6 |
None that I should talk about, sorry. They're out there though!
| Thread Closed |
| Tags |
| air-fuel mixture, combustion chamber, engine, injector |
| Thread Tools | |
Similar Threads for: Devices that can inject air-fuel mixture into the combustion chamber
| Heat transfer inside engine combustion chamber | General Engineering | 3 | ||
| Designing an inline flare gas combustion chamber | General Engineering | 1 | ||
| View Windows on a Combustion Chamber | Materials & Chemical Engineering | 3 | ||
| Rocket Engine Combustion Chamber Equations | Mechanical Engineering | 4 | ||
| L head combustion chamber | Mechanical Engineering | 1 | ||
