Determine the mass of the star?
  • Thread starter Thread starter ohheytai
    Mass Star
The discussion revolves around determining the mass of a star based on gravitational interactions in an orbital context. The original poster expresses confusion regarding the problem and seeks assistance in understanding the relevant equations and concepts.
  • Participants discuss the relationship between centripetal force and gravitational force in circular motion. One participant attempts to derive the mass of the star using given quantities and equations, while others question the necessity of centripetal force in the analysis and explore the use of vectors.
There is an ongoing exploration of different approaches to the problem, with one participant providing a mathematical derivation and others questioning the assumptions made. Some guidance has been offered regarding the relationship between forces, but no consensus has been reached on the best method to approach the problem.
Participants note the dimensions of gravitational constant G and its implications for the derived expressions. There is an emphasis on understanding the role of gravitational force in orbital mechanics, with some constraints on the methods being discussed.
ohheytai
Uploaded the PDF someone please help me i have no idea what to do!
(-G*m1*m2)/r^2
dP/dt
I don't even know where to start i drew everything out and i think dP/dT is 0 cause its at a constant speed someone please help! :(
At constant speed in circular motion, acceleration would be constant towards the centre, creating the centripetal force, Fc.
In the case of orbit, Fc = Fg = GMstarMplanet / R2
R, T and G are given, so all you need to do is to derive the mass of the planet in terms of the given quantities.
Rearranging the expression to find star's mass, I get:
Mstar = Fc R2 / G Mplanet
The only unknowns left will be Fc and mass of planet.
However, it is known that Fc = Mplanet v2 / R. Thus, the mass of planet in Fc can be canceled with the mass of planet in my arranged expression above to give:
Mstar = v2 R / G
v = 2pi R / T (given in question as well), thus, final expression being:
Mstar = 4 pi2 R 3 / G T 2
This is just my first try. please let me know if I've made any errors or if you disagree.
is it possible to do this without centripetal force? and using vectors?
Dimension for G is m3 kg-1 s-2, making the overall expression's dimension kg as well. So my expression SHOULD be correct.
The purpose of this problem is to emphasize that in an orbit, the centripetal force is the gravitational force, and thus using simple algebra, master the variables of the expression for Fg.
Vectors will point only the tangential velocity and Fc, but to determine the mass, you need expression for Fg.
okay thank youuu!
  • · Replies 27 ·
  • · Replies 19 ·
  • · Replies 17 ·
  • · Replies 33 ·
