Complex numbers, inverse trig and hyperbolic
The discussion revolves around verifying formulas related to inverse trigonometric functions for complex numbers, specifically arcsin and arccos. Participants are exploring the relationships and transformations involving complex logarithms and trigonometric identities.
  • Participants are attempting to manipulate the given formulas and explore the implications of using complex logarithms. There are discussions about substituting variables and the challenges of notation in complex analysis.
Some participants have shared steps and suggestions for approaching the problem, while others express uncertainty about their attempts and the correctness of their results. There is an ongoing exploration of different methods and interpretations without a clear consensus.
Participants note the importance of adhering to specific notation and definitions in complex analysis, which may affect their approaches and understanding of the problem.
Liquidxlax
edit* It says Verify the formulas in problems
arcsin(z) = -iln(iz ±sqrt(1-z^2))
arccos(z) = iln(z ±sqrt(1-z^2))tanh-1z = (1/2)ln((1+z)/(1-z))
yeah, my prof just threw it at us, all i have is nothing... absolutely nothing. I don't know why he does this to us.
The best i can think of isz= sin(-iln(iz ±sqrt(1-z^2)))
z = (eln(iz ±sqrt(1-z^2)) + e-ln(iz ±sqrt(1-z^2)))/2i((iz ±sqrt(1-z^2)) + (iz ±sqrt(1-z^2)-1)/2i
but i doubt that is right
You have really got to get squared with the complex logarithm and stop using the ln symbol to denote it. Use ln only when referring to the real log function. Use log to refer to the complex log function.
So we know:
[tex]\sin(z)=\frac{e^{iz}-e^{-iz}}{2i}=w[/tex]
Now, how do you solve for z in that? I'll show you some of the steps. You try to fill in the blanks if you want:
[tex]2iw=e^{iz}-\frac{1}{e^{iz}}[/tex]
[tex]2iwe^{iz}=e^{2iz}-1[/tex]
[tex]e^{iz}=\frac{2iw+\sqrt{-4w^2+4}}{2}[/tex]
[tex]iz=\log(iw+\sqrt{1-w^2})[/tex]
Go through that one, then try arccos(z) the same way.
Keep in mind that's a complex log function: [itex]\log(z)=\ln|z|+i(\theta+2n\pi)[/itex] and note I do not use [itex]\pm[/itex] for the root. In Complex Analysis, it's implied to have two values. So the arcsin function is infinitely-valued and for each one of those n-values of the log function, the square root has two different values. So if I asked what is the arcsin(z) when n=10,11, there would be four values of the arcsin function for those two values of n.
Hi Liquidxlax! :smile:
(have a square-root: √ and a theta: θ and try using the X2 icon just above the Reply box :wink:)
eugh! … let's keep this simple
whenever I see √(1 - z2), I immediately want to do a trig subsitution.
So forget about the LHS, and just put z = sinθ in the RHS …
what do you get? :wink:
(have a square-root: √ and a theta: θ and try using the X2 icon just above the Reply box :wink:)eugh! … let's keep this simple
i don't think that will help, but i did what jack said, yet i did not get the right answerfor arcsin
(iz +- sqrt(1-z^2))^2 = Log(iz +- sqrt(1-z^2)) somehow
Tell you what, start with:
[tex]w=\frac{e^{iz}-e^{-iz}}{2i}[/tex]
and solving for z like I showed above, do you not get the same expressions I obtain in the above post?
nope... but isn't it arcsinz = w, or should i ignore the rhs and just say
arcsinz = w => z=sinw => z = (e^iw - e^-iw)/2i. I mean they're very very stict with notation and variables i can't be changing them randomly even if i do say let z = w or something, they still whine and complain.
being my typical in a rush self, i slowed down and did what you said Jackmell, and it worked just fine
10K
