Calculating Ka and Kb values from estimated pH values
  • Thread starter Thread starter TrueStar
    Ph
The discussion revolves around calculating the acid dissociation constant (Ka) and base dissociation constant (Kb) values from estimated pH values of various solutions, specifically focusing on salts such as NaCl and ZnCl2. Participants explore the theoretical underpinnings of these calculations, including the use of ICE tables and the behavior of ions in solution.
  • Homework-related
  • One participant expresses confusion about calculating Ka and Kb values for salts like NaCl and ZnCl2, noting estimated pH values and the use of ICE tables.
  • Another participant clarifies that NaCl does not have a Ka or Kb value due to the absence of a reaction affecting pH.
  • Discussion on ZnCl2 includes the idea that Zn2+ is a highly charged metal that may undergo hydration, leading to acidic behavior in solution.
  • One participant proposes a reaction involving Zn2+ and water, suggesting a potential Ka expression for the hydrated form of Zn.
  • Another participant emphasizes that water concentration can be considered constant in the Ka expression, which may differ from initial assumptions about including water in the equation.
  • Participants express uncertainty about starting concentrations for the ICE table when transitioning from ZnCl2 to its hydrated form.
Participants generally agree on the behavior of NaCl as neutral and lacking Ka or Kb values. However, there is ongoing discussion and uncertainty regarding the calculations and reactions involving ZnCl2, with no consensus reached on the specifics of the Ka expression or the initial conditions for the ICE table.
Participants note that these topics have not been fully covered in their lectures, indicating potential gaps in understanding that may affect their calculations and interpretations.
Students working on chemistry lab reports involving acid-base equilibria, particularly those dealing with salts and their dissociation in solution.
TrueStar
In our chemistry lab, we estimated the pH values of various solutions using six different indicators. Based on these estimated pH values, we must calculate [H+] and the estimated Ka or Kb values.
For pH - ph=-log[H+}
For Ka and Kb values - Concentrations of Product / Concentrations of Reactant
I think I'm having the most trouble with the salts, like NaCl and ZnCl2. My estimated pH values for NaCl and ZnCl2 are 6.7 and 4.3 respectively.
I think I'm supposed to set up an ICE table for problems likes these, but I'm not sure. With another solution we tried (NaCH3CO2), you clearly see that OH- is produced when added into water. In this case, we took out estimated pH (7.7) and subtracted that number from 14 to get 6.3 which is the pOH. From this, I calculated that the concentration of OH is about 5.01x10^-7. I divided the concentration of NaCH3CO2, which was 0.10, by this number and I think my estimated Kb value is about 5x10^-6.
I don't know how to translate these kinds of calculations to the salts. NaCl is neutral.
I do know that water goes through autoionization, but I'm not sure if this has any role in calculating the Ka/Kb values for NaCl and ZnCl2.
Long story short, I'm not sure how to calculate my estimated Ka/Kb values for NaCl and ZnCl2...even assuming I'm calculating them correctly for solutions like NaCH3CO2.
Thank you!
First step would be always to correctly identify the reaction responsible for pH change.
In the case of NaCl there is no reaction and there is no Ka nor Kb value.
In other cases you should start writing expressions for Ka (or Kb). Think what you can tell about concentrations of all substances involved. Perhaps you can use stoichiometry to calculate them?
Zn2+ seems to be acidic. Can you think of a reaction that will make it behave this way?
Hi Borek:
Thank you for clarifying the issue with NaCl.
As for ZnCL2, it dissolves with water to product Zn2+ and 2Cl-. However, I think Zn2+ would be a highly charged metal. That means, I think, that when the salt dissolves in water, the Zn2+ will become hydrated.
Something like Zn2+ + H2O [tex]\rightarrow[/tex] Zn(H2O)2+ I'm not sure what the coefficients should be here. This also means that -
Zn(H2O)2+ + H2O [tex]\Leftrightarrow[/tex] Zn(H2O)(OH)+ + H3O+
That is what makes this acidic and this is the information I would use to set up my Ka equation. That would look like.
Ka = [Zn(H2O)(OH)+][H3O] / [Zn(H2O)2+][H2O]
I need to add H2O to this equation because it's an aqueous solution at this point. Then I set up my ICE table, but now I'm not sure what number to start with since I'm longer working with ZnCl anymore. Would I calculate the [H+] concentration and use it for H3O+ at equilibrium?
Thanks. Let me know if I've gone wrong anywhere in my post.
That's the idea behind.
You don't need water here. I know it sounds counterintuitive, but the way this is usually done we are assuming concentration of water is sonstant (and in fact in most solutions it doesn;t change much) and we make it a part of dissociation constant.
Concentration of hydrated Zn is identical to concentration of ZnCl2.
Thank you Borek. :)
I'm discovering that these are topics that we haven't gone over in our lectures yet. I'm hoping by the end of this week, this will all be crystal clear.
At least I can get started on my lab report.
