Schrodinger ground state wave function
The discussion revolves around finding the ground state wave function for a one-dimensional particle in a box, where the potential is zero between x = -a/2 and x = a/2, and infinite outside this range. Participants are exploring the implications of Schrödinger's time-independent equation in this context.
  • Participants discuss the simplification of Schrödinger's equation when the potential is zero and the resulting differential equation. They explore the general solutions for the wave function within the box and question how to handle the infinite potential outside the box.
The conversation is active, with participants sharing their attempts and seeking clarification on the boundary conditions and the behavior of the wave function at the edges of the box. There is an ongoing exploration of how the solutions in different regions relate to each other.
Participants are considering the implications of the infinite potential outside the defined region and how this affects the wave function, particularly in terms of boundary conditions and continuity at the edges of the box.
wrongusername
Find the ground state wave function for the 1-D particle in a box if V = 0 between x = -a/2 and x = a/2 and V = [tex]\infty[/tex]
I would guess -- Schrödinger's time-independent equation?
[tex]\frac{-\hbar^{2}}{2m}\frac{d^{2}\psi}{dx^{2}}+V\left(x\right)\psi=E\psi[/tex]
[tex]V\left(x\right)=0[/tex] for [tex]-\frac{a}{2}\leq x\leq\frac{a}{2}[/tex]
So then, we don't need the V(x) term in the equation, and it simplifies to [tex]\frac{-\hbar^{2}}{2m}\frac{d^{2}\psi}{dx^{2}}=E\psi[/tex]
So now I move the nasty stuff over to the right side:
[tex]E\psi+\frac{\hbar^{2}}{2m}\frac{d^{2}\psi}{dx^{2}}=0[/tex]
[tex]\frac{2mE}{\hbar^{2}}\psi+\frac{d^{2}\psi}{dx^{2}}=0[/tex]
Now I use a trick from my book:
[tex]k^{2}=\frac{2mE}{\hbar^{2}}[/tex]
[tex]\frac{d^{2}\psi}{dx^{2}}+k^{2}\psi=0[/tex]
And now there's 2 solutions to this differential equation: [tex]\psi=A\cos\left(kx\right)[/tex] and [tex]\psi=A\sin\left(kx\right)[/tex]. Where do i go from here? I am quite lost unfortunately :frown:
Hi wrongusername,
The general solution for the part from -a/2 to a/2 will be a linear combination of those two solutions (A cos(kx) + B sin(kx) ).
So you've found the solution in that area, now what is the solution for those places outside the box? And what has to be true about these three separate solutions?
alphysicist said:
Hi wrongusername,
Thank you for the reply!
Well, [tex]V\left(x\right)=\infty[/tex] for all x not between -a/2 and a/2, though if I plug infinity in for V in the Schrödinger equation, I would get [tex]\infty=E\psi[/tex]?
Wouldn't it be two solutions since, like you said, the two solutions would be combined into one general solution with a linear combination?
All three solutions would have to reflect the ground state energy? I'm not sure how though...
No, I don't think that would be quite helpful here. Instead, leave it as V, but keep in mind that V>E. Find the solution (using your trick to get the equation into a similar form as before), and then let V go to infinity.
Remember that here we want the wavefunction to go to zero as x goes to plus or minus infinity.
Every region will have two mathematical solutions; but boundary conditions will set some constants equal to zero, force values for others, etc.
There is one wavefunction they are looking here, that is made up of the solutions you found in each region. But look at, for example, the point x=a/2. There the solution from the inner region (-a/2 < x < a/2) is meeting the solution from the right side (x > a/2). How do they go together? What property of the wavefunction is used at a/2?
  • · Replies 22 ·
