Linear System of ODEs: Solving for n=1 or n=3
The discussion focuses on solving a system of ordinary differential equations (ODEs) defined by the equations α' + (n-1)/(2r) α = 0 and α'' + (n-1)/r α' = 0. The solutions derived are α = r^{-(n-1)/2} for the first equation and α' = r^{-(n-1)} for the second. The key conclusion is that the equations yield consistent solutions specifically for n=3, while n=1 presents complications due to singular behavior. Careful algebraic manipulation is essential to reconcile the solutions across different values of n.
  • Understanding of ordinary differential equations (ODEs)
  • Familiarity with algebraic manipulation and singularities
  • Knowledge of wave attenuation and distortion concepts
  • Experience with mathematical notation and power functions
  • Study the behavior of linear systems of ODEs with varying parameters
  • Learn about singular solutions in differential equations
  • Explore wave attenuation models in physics
  • Investigate the implications of arbitrary scalar factors in ODE solutions
Mathematicians, physicists, and engineering students dealing with wave phenomena and differential equations, particularly those focusing on linear systems and their solutions.
McCoy13
I'm trying to solve the following system of ODEs.
[tex]\alpha = \alpha (r)[/tex]
[tex]\alpha ' + \frac{n-1}{2r} \alpha =0[/tex]
[tex]\alpha '' + \frac{n-1}{r} \alpha ' = 0[/tex]
The attempt at a solution
The solution to the first one is
[tex]\alpha = r^{\frac{-(n-1)}{2}[/tex]
The solution to the second one is
[tex]\alpha '= r^{-(n-1)}[/tex]
Ultimately the goal is to show that n=1 or n=3 (it's a problem dealing with wave attenuation and distortion, but I'm just having problems with this step). I really can't reconcile these answers, even using arbitrary scalar factors against my solutions. When I tried substituting one equation into the other all that happened was I ended up with a factor of sqrt(2) that wasn't consistent with either equation individually.
The solutions to these equations do match when n=3, just be a bit more careful with the algebra. The equations themselves are not well-behaved when n=1, so you should be careful when trying to match the solutions for arbitrary n to the limit n->1. It happens to work for the first equation, but there is an additional solution of the second that is not a solution to the first.
Gah, I see. I think I was forgetting that r was to a negative power when I was thinking about it in the case n = 3 and in the case n = 1 I wasn't looking at the equations, just the solutions, so I missed the fact that they sort of become singular. Thanks for elucidating.
  • · Replies 22 ·
  • · Replies 16 ·
