Calculating Expectation Value for z component of angular momentum
The discussion focuses on calculating the expectation value for the z component of angular momentum, represented by the operator \(\hat{L}_z = -i \hbar \left (x \frac{\partial}{\partial y} - y \frac{\partial}{\partial x} \right )\), for the wave function \(\psi = \sin(x)e^{ix}\). The expectation value is computed using the formula \(\langle L_z \rangle = \int \psi^*(x) \hat{L}_z \psi(x) dx\). Participants emphasize the necessity of normalizing the wave function before performing the integral to ensure accurate results.
  • Understanding of quantum mechanics, specifically angular momentum operators.
  • Familiarity with wave functions and their normalization.
  • Knowledge of complex conjugates in quantum mechanical calculations.
  • Proficiency in performing integrals involving complex functions.
  • Study the normalization of wave functions in quantum mechanics.
  • Learn about the derivation and application of angular momentum operators in quantum systems.
  • Explore the calculation of expectation values for different quantum operators.
  • Investigate the properties of complex functions in integrals.
Students and professionals in quantum mechanics, physicists working with angular momentum, and anyone interested in the mathematical foundations of quantum theory.
TLeo198
Calculate the expectation value for the z component of angular momentum (operator is (h/i)(d/dx)) for the function sinx*e^(ix).
I think the only one relevant is the expectation value:
<a> = integral[psi*(a)psi] / integral[psi*psi] where psi* is the complex conjugate and a is the operator (in this case, the operator of the z component of angular momentum).
I don't really know how to begin this one, but I assume that you have to find the <a> equation where <a> is the expectation value. In that case, do you just take the integral of psi*(a)psi over the integral of psi*psi? In this case, psi = sinx*e^(ix)
The operator you wrote down is for momentum:
[tex]\hat p = \frac{\hbar}{i} \frac{\partial}{\partial x}[/tex]
However, the angular momentum operator is different:
[tex]\hat L_z = -i \hbar \left (x \frac{\partial}{\partial y} - y \frac{\partial}{\partial x} \right )[/tex]
Yes. To be clear, you want to calculate the following:
[tex]<L_z> = \int \psi^*(x) \hat L_z \psi(x) dx[/tex]
In order to use this definition, you will first have to normalize the wavefunction (so that the denominator in your expression is equal to 1)
  • · Replies 30 ·
  • · Replies 0 ·
