Can Teleportation Become a Reality?
  • Context: Graduate
  • Thread starter Thread starter TriKri
    Teleportation
The discussion centers around the concept of teleportation, particularly in the context of quantum teleportation and its theoretical implications. Participants explore the feasibility of teleporting particles, the distinction between teleportation and quantum teleportation, and the underlying theories that might support such phenomena.
  • Some participants mention an experiment where a photon was teleported, questioning the mechanics and theories behind teleportation.
  • One participant distinguishes between teleportation and quantum teleportation, stating that the latter involves transmitting the quantum state rather than the particle itself.
  • Another participant proposes a theoretical framework where a massive particle could be annihilated, its quantum state transmitted, and then recreated at a distant location, suggesting this could allow for transportation at light speed.
  • There is a contention regarding the nature of quantum teleportation, with one participant arguing that teleporting the state of a particle is equivalent to teleporting the particle itself, emphasizing the indistinguishability of particles.
  • Some participants express uncertainty about whether an electron can be teleported from one location to another, with a focus on the implications of such an event on the existence of the original particle.
  • One participant asserts that quantum entanglement plays a crucial role in the teleportation process, linking it to the broader discussion of particle states and locations.
Participants express differing views on the definitions and implications of teleportation and quantum teleportation. There is no consensus on whether teleporting a particle is the same as teleporting its quantum state, and the discussion remains unresolved regarding the practicalities and theoretical underpinnings of teleportation.
Participants highlight various technical challenges and assumptions related to the annihilation and recreation of particles, as well as the need for precise communication mechanisms. The discussion reflects a range of interpretations of quantum mechanics and its implications for teleportation.
TriKri
Hi,
I hear a few years ago about an experiment in which some scientists had succeeded to teleport a photon a short distance. Is this really possible? In that case, how does it work, and what theory do you have to use to make teleportation possible? In which speed does the teleported object travel while being teleported?
Watch out there is a trick in the language. There is
1) teleportation
2) quantum teleportation
Quantum teleportation is defined by some as the transmission of the full quantum state of a particle from point A to point B using standard communication mechanisms. This does not mean transporting the particle from location A to location B only the information about the full quantum state.
That will suffice. You can annihilate a massive particle, turn it into photons carrying information about its quantum state, send them to some other planet and use them to re-create the original particle. This will allow transportation of massive objects at light speed, provided that the necessary energy is already at the destination point.
So, "teleportation" as seen in Star Trek is at least theoretically possible, except there is no means to copy the transported object, and the effects of disturbing the communication signal would be less pleasing.
Technical difficulties to overcome:
1. You have to annihilate a whole human body, so you have to prepare some bit of antimatter.
2. You have to be annihilating it so slowly, so that the heat does not destroy the teleporter or the planet.
3. You have to be annihilating it so fast, so that the untouched parts don't move relative to the already annihilated parts (or perhaps freeze it near 0 Kelvin before the teleportation).
4. You have to collect all information of the system (every damn photon) and store it in some quantum computer.
5. You have to send the data to other planet with virtually no interference from anyting.
6. You have to have big amount of energy at the destination point, ready to use before the teleportation and quantum-entangled with the antimatter used to annihilate the body.
7. You have to re-create the matter from received photons, getting back the body and the original antimatter.
This seems complex, but is possible in principle. Laws of physics allow as to turn matter into massless information, send it away and turn back to matter. So, it's only the matter of time before people start sending themselves to distant places through network :).
What you are saying is nonsense. Teleporting state of a particle is the same thing as teleporting a particle. All particles are indistinguishable. You cannot tell if particle A is here and particle B is at Alpha Centauri, or if it's particle B here and A there. What makes them different is their states.
Suppose I have an electron in the state a|+> + b|->. I want to use teleportation to swap it with another electron that has state c|+> + d|-> and is located elsewhere. The wave function is going to be something like:
φ(x1)(a|+> + b|->) * ψ(x2)(c|+> + d|->) - φ(x2)(a|+> + b|->) * ψ(x1)(c|+> + d|->)
If I swap particles, I must swap φ and ψ which give locations of the two particles.
ψ(x1)(a|+> + b|->) * φ(x2)(c|+> + d|->) - ψ(x2)(a|+> + b|->) * φ(x1)(c|+> + d|->)
Now let's swap the particle spin-states instead.
φ(x1)(c|+> + d|->) * ψ(x2)(a|+> + b|->) - φ(x2)(c|+> + d|->) * ψ(x1)(a|+> + b|->)
Exactly the same thing except for the overall sign change. Note that the overall phase is undetectable and will never make a difference. If you use bosons instead, even the sign stays the same.Now consider complex multi-particle systems. The relative "locations" of particles are also just quantum states of the system. You quantum-teleport these, and it's the same thing as teleporting the system. You just have to make sure you have elementary particles to build stuff out of, and these are the same elementary particles in any part of the universe.
Quantum Teleportation is teleportation. No qualifiers needed.
Could be wrong, but I think the OP is asking if, say, an electron which exists at location (a) can be teleported to location (b) which previously had no electron. And, that the electron at location (a) ceases to exists after this "teleportation"
If this is correct, this is very distinct from quantum entanglement.
Yes, it is possible, with the light speed.
This is all thanks to quantum entanglement.
  • · Replies 0 ·
  • · Replies 473 ·
34K
