Law conservation of charge relativistic
The discussion revolves around the conservation of charge in the context of relativistic physics, specifically examining the mathematical formulations involving divergence and current density in four-dimensional spacetime. Participants explore the implications of these formulations, the definitions of divergence and curl, and the conditions under which charge conservation holds.
  • One participant presents the charge continuity equation and questions the definition of divergence in a relativistic context.
  • Another participant asserts that if charge is conserved, then the divergence of the current density must equal zero, linking it to physical interpretations of charge flow.
  • A different viewpoint suggests that simply defining the current density as a contravariant vector does not inherently lead to charge conservation, emphasizing the need to combine Ampere's and Gauss's laws.
  • One participant proposes a specific form of the charge continuity equation using covariant derivatives, asserting that it results in a scalar that is zero due to the commutation of partial derivatives.
  • Several participants express confusion regarding the definitions and operations of divergence and curl, with one noting that these concepts become clearer with advanced mathematical understanding.
  • There are repeated assertions of the conservation of charge through the divergence of the current density, with some participants expressing agreement on this point.
  • One participant critiques another's question for being unclear and emphasizes the importance of clarity in communication.
While some participants agree on the formulation of charge conservation through divergence, there is no consensus on the definitions and implications of divergence and curl, nor on the sufficiency of the proposed definitions for establishing charge conservation.
Participants express uncertainty regarding the mathematical definitions and operations involved, particularly in the context of four-dimensional spacetime. There are unresolved questions about the clarity of certain contributions and the implications of reversing current flow.
Petar Mali
[tex]\frac{\partial \rho}{\partial t}+div\vec{j}=0[/tex]
In Deckart coordinate system
[tex]\frac{\partial j_x}{\partial x}+\frac{\partial j_y}{\partial _y}+\frac{\partial j_z}{\partial _z}+\frac{\partial (c\rho)}{\partial (ct)}=0[/tex]
definition
[tex]divA^{\mu}=\frac{\partial A^{\mu}}{\partial x^{\mu}}[/tex]
scalar (invariant)
Why I define divergence like that? Is there some certain rules for that?
[tex]j^{\mu}=(j_x,j_y,j_z,c\rho)=(\vec{j},c\rho)[/tex]
[tex]\frac{\partial j^{\mu}}{\partial x^{\mu}}=0[/tex]
[tex]divj^{\mu}=0[/tex]
Now is satisfied
[tex]j_{\mu}=(-\vec{j},c\rho)[/tex]
Can I interprate this like time inversion. Changing od indeces, think of that?
What is with
[tex]divj_{\mu}=?[/tex]
I'm not sure what you're asking, but if charge is conserved then [itex]\frac{\partial \rho}{\partial t}=0[/itex] and so [itex]\nabla j_\mu=0[/itex]. Physically this means that the amount of charge entering a volume of space must be equal to the amount leaving the volume. Or, expressed as a surface integral, the current crossing the boundary of the volume is zero. Hence
[tex] \nabla j_\mu=0 \rightarrow \nabla( -j_\mu)=0[/tex]
just means that reversing the current leaves the divergence unchanged. If [itex]\frac{\partial \rho}{\partial t}\ne 0[/itex] then reversing the current changes the sign of [itex]\frac{\partial \rho}{\partial t}[/itex].
See Stoke's theorem.
You cannot obtain the conservation of charge simply by proposing that
[tex] j^{\mu}=(j_x,j_y,j_z,c\rho)=(\vec{j},c\rho)[/tex]
is a perfectly good contravariant vector in four dimensions. And it is.
You're on the right track. It just doesn't lead to conservation of charge. You need to combine Ampere's law and Gauss's law to get charge conservation. Normally it is called the "charge continuity equation" that you might find in wikipedia.
(Mentz114, I'm still thinking over your posts in another thread, thinking of something intelligent to add.)
My question is bold in the text and also after them is very interesting sign ?
@ Phrak
[tex] divj^{\mu}=0[/tex]
This is law conservation of charge. I don't see why it wasn't finished?
You should drop the dot product convention and adhere to valid tensor operations in the four dimensions of spacetime.
With this, in simplest form, the charge continuity equation is
[itex]D_\mu J^\mu = 0[/itex]
where
[tex]D_\mu = (\frac{\partial}{\partial x}, \frac{\partial}{\partial y}, \frac{\partial}{\partial z}, -\frac{\partial}{c\partial t})[/itex]<br /> and<br /> [tex]J^\mu = (j_x, j_y, j_z, c\rho)[/itex]<br /> <br /> The result is a scalar. It could be any scalar, but it is zero because both charge and current are derivatives of the electric and magnetic fields. It happens to be zero because partial derivatives commute. <br /> <br /> [tex]\frac{\partial}{\partial x^i} \frac{\partial}{\partial x^j} -<br /> \frac{\partial}{\partial x^j} \frac{\partial}{\partial x^i}=0[/itex]<br /> <br /> You can find all of this is wikipedia somewhere where you would find that J is a derivative of the Faraday tensor.[/tex][/tex][/tex]
I don't understand. Ask again.
I have problems with definition of divergence and curl (rot)
[tex] divA^{\mu}=\frac{\partial A^{\mu}}{\partial x^{\mu}}[/tex]
[tex]rotA_{\mu}=\frac{\partial A_{\nu}}{\partial x^{\mu}}-\frac{\partial A_{\mu}}{\partial x^{\nu}}[/tex]
Why I define this like that?
In one mathematical physics book I find
[tex](rotA_i)_j=\frac{\partial A_i}{\partial x^j}-\frac{\partial A_j}{\partial x^i}[/tex]
Yes, divergence and curl are very confusing operators at first. In more advanced mathematics they finally make sense.
They make more sense understood as a dot product and a cross product.
The partials,
[itex]\nabla = \left( \frac{\partial}{\partial x},\frac{\partial}{\partial y},\frac{\partial}{\partial z} \right)[/itex]
is a vector in three dimensions.
A vector such as
[itex]\left( A\frac{\partial}{\partial x},B\frac{\partial}{\partial y},C\frac{\partial}{\partial z} \right)[/itex]
obeys all the rules of a vector space over the field of real numbers.
Petar Mali said:
@ Phrak
Now I understand. Yes, this is conservation of charge.
Petar Mali, when someone points out that your question is confusing it will be more productive to clarify your intention rather than to point out some trivial formatting. For example the following question:
Is indeed in bold and does have a question mark afterwards, but it is gramattically incorrect and meaningless despite the presence of the correct formatting. It is not that your questions could not be found, but that they could not be understood.
  • · Replies 44 ·
  • · Replies 17 ·
  • · Replies 21 ·
