Finding the Smallest Solution with Condition a: minSol Function
  • Thread starter Thread starter anonymous_w
    Condition Function
The discussion focuses on implementing the Haskell function minSol :: Ord a => Condition a -> [a] -> Maybe a, which identifies the smallest element in a list that satisfies a specified condition. The Condition a type is defined as data Condition a = Con (a -> Bool). Participants suggest using recursion and pattern matching to traverse the list, and mention that the solution can be simplified using GHC with standard library imports. The conversation emphasizes the importance of applying the condition to each list element effectively.
  • Understanding of Haskell syntax and type definitions
  • Familiarity with polymorphic data types in Haskell
  • Knowledge of recursion and pattern matching in functional programming
  • Experience with GHC and Haskell's standard library modules
  • Research Haskell's filter function for conditionally processing lists
  • Learn about Haskell's Maybe type for handling optional values
  • Explore advanced recursion techniques in Haskell
  • Investigate Haskell's standard library modules for additional list processing functions
Haskell developers, students learning functional programming, and anyone interested in optimizing list processing with conditions in Haskell.
anonymous_w
'Condition' is a function which determines whether an element of some type a satisfies some property, and returns True if only if it does. A polymorphic data type 'Condition a' is defined:
Define a function minSol::Ord a => Condition a -> [a] -> Maybe a which takes a condition as its first argument, a list of possible solutions as its second argument, and returns the smallest solution found in the list which satisfies the condition. If no solution is found, the function should return the value Nothing.
I tried to use lambda but I'm not sure how to recursively apply it to every element in the list and I think the smallest element can be determined by (<) or min.
Technology news on Phys.org
Is this for a class? If so, what are you covering now, or what have you covered? There are several ways to check each element of the list. Although, since you mentioned recursion, have you tried pattern matching?
I've got a solution, but I'd like to see what you come up with first. Have you attempted any code at all? If so, post it.
Sorry for the double post, but are you using GHC? If so, this can be written nicely in two lines of code when you import a couple of modules from the standard library.
  • · Replies 29 ·
  • · Replies 17 ·
  • · Replies 16 ·
