Conservation of Energy: Kinetic to Elastic Potential
The discussion focuses on the conservation of energy principles applied to a system involving a 0.150-kg frame and a 0.200-kg lump of putty. The frame stretches a coil spring by 0.050m when suspended, while the putty is dropped from a height of 30.0m. The initial calculations for spring constant (k = 29.4 N/m) and velocity of the putty upon impact are correct, but the error arises in assuming the putty and frame move together at the same speed post-collision. The correct approach requires calculating the combined speed of the putty-frame system immediately after the collision to determine the final displacement accurately.
  • Understanding of Newton's laws of motion
  • Familiarity with the principles of conservation of energy
  • Knowledge of spring mechanics and Hooke's Law
  • Basic algebra for solving equations involving kinetic and potential energy
  • Study the concept of inelastic collisions and momentum conservation
  • Learn about energy transformations in mechanical systems
  • Explore advanced applications of Hooke's Law in real-world scenarios
  • Investigate the effects of different masses on spring displacement
Students studying physics, particularly those focusing on mechanics, as well as educators seeking to clarify concepts related to energy conservation and spring dynamics.
awelex
A 0.150-kg frame, when suspended from a coil spring, stretches the spring 0.050m. A 0.200-kg lump of putty is dropped from rest onto the frame from a height of 30.0m.
mass of frame: mf
mass of putty: mp
height: h
I tried the following, which was wrong:
0.150 * 9.8 = k * 0.050 --> k = 29.4
velocity of putty when it touches frame:
0.200*g*0.3=(1/2)*0.200*v^2 --> v^2 = 2hg
(1/2)(mp+mf)*v^2 = (1/2)*k*x^2
--> x = 0.2m
So the final answer is either 0.2m or 0.25m (depending on whether one adds the initial 0.05m). Both answers are wrong, though. What am I doing wrong?
Thanks.
mass of frame: mf
mass of putty: mp
height: h
You're fine up to here. I take it that h=30 cm, not 30 m like you wrote above.
--> x = 0.2m
Thanks.
You're assuming that both the frame and the putty are initially moving with the speed the putty had just before hitting the frame. So right before the collision, the putty has a certain amount of kinetic energy, and immediately after the collision, it still has that amount of kinetic energy because it still has speed v. But now the frame is moving too, so there's even more kinetic energy. Does that make sense?
You need to find the speed of the putty-frame combination immediately after the collision. If you use that speed in your calculations instead, you should get the right answer.
