Open and closed intervals and real numbers
The discussion revolves around proving the existence of unique numbers a and b in the real numbers such that a < b, given a subset S of the real numbers that is bounded above and below, and contains all numbers between any two distinct elements x and y in S. The problem is situated within the context of real analysis, specifically focusing on intervals and properties of bounded sets.
  • Participants discuss the necessity of establishing a greatest lower bound and a least upper bound for the set S, referencing the Dedekind completeness theorem. There is consideration of how to demonstrate the uniqueness of a and b and the types of intervals S could represent.
The conversation is progressing with participants building on each other's ideas, particularly regarding the implications of the Dedekind completeness theorem. There is an ongoing exploration of the uniqueness of the supremum and infimum, with some participants suggesting that the proof may be straightforward.
Participants are operating under the assumption that S is nonempty and bounded, and there is a focus on the definitions of supremum and infimum as they relate to the problem. The discussion also references specific theorems and properties relevant to real numbers.
reb659
Show that:
Let S be a subset of the real numbers such that S is bounded above and below and
if some x and y are in S with x not equal to y, then all numbers between x and y are in S.
then there exist unique numbers a and b in R with a<b such that S is one of the intervals (a,b), [a,b), (a,b], or [a,b].
Assume if x and y are elements of S with x not equal to y, then all numbers between x and y are in S and S is bounded above and below.
Thus there exists a M, N such that M is greater than or equal to the maximal element of S and N is smaller than the minimal element of S. Also all elements between x and y are inside (M,N).
hi reb659! :smile:
i think i'd start by proving that there must be a greatest lower bound and a least upper bound, and then call them a and b, and carry on from there. :wink:
Good idea.
Isn't it an axiom that if a nonempty subset of R has an upper bound, then it has a least upper bound/sup(S)?
I don't think it's an axiom, I think it's the Dedekind-completeness theorem:
A bounded real-valued function has a least upper bound and a greatest lower bound.
(See Rolle's theorem in the PF Library :wink:)
So far:
Since S is bounded above and below, by Dedekind completeness there exists a supremum of S. Call it b. Again by dedekind completeness we can say there exists an infimum of S. Call it b. By definition of sup and inf, a<b. We are left to show a,b are unique and that S is exactly one of the intervals in the OP.
To show this, can't we consider four simple different cases in which a,b are either in S or outside of it?
Yup, that's the proof! :smile:
Yay!
How exactly does uniqueness follow though? It seems like its trivial to prove.
as you said, "by Dedekind completeness there exists a supremum of S" …
there can't be two supremums, can there? :wink:
