How Much Force is Needed to Stop a 1520kg Car in 57.5 Meters?
The discussion centers on calculating the net force required to stop a 1520 kg car traveling at 15.0 m/s over a distance of 57.5 meters. The correct formula for acceleration is a = (V^2 - Vo^2) / 2x, which yields an acceleration of -1.96 m/s². The net force is then calculated using net force = m(a), resulting in a force of -2973.9 N. The negative sign indicates the force acts in the opposite direction of the car's motion, confirming the calculations are accurate when considering direction.
  • Understanding of Newton's Second Law of Motion
  • Familiarity with kinematic equations
  • Knowledge of unit conversion (kilograms, meters, seconds)
  • Basic principles of force and acceleration
  • Study kinematic equations in detail, focusing on their applications in motion problems
  • Learn about vector forces and their implications in physics
  • Explore unit conversion techniques for physics calculations
  • Practice solving real-world problems involving force and motion
This discussion is beneficial for physics students, educators, and anyone interested in understanding the principles of motion and force calculations in real-world scenarios.
BlackMamba
My problem invloves a car with a mass of 1520kg. It's traveling with a speed of 15.0 m/s. I'm asked to find the magnitude of the horizontal net force that is require to bring the car to a halt at 57.5m.
My reasoning begins, in that I think I should be finding the acceleration and once I've found the acceleration I can find the total force. But, this is producing a rather large number for me that is negative.
To find the acceleration I used the equation: a = V^2 - Vo^2 / 2x
Using that equation my answer was -1.96
I then plugged that into the equation for net force which was: net force = m(a)
Plugging in the variables I know in that got me the answer -2973.9 But I can't imagine that this is correct.
Any help would be appreciated.
Again, nevermind. What I did was correct however, I should have been leaving out the negative sign. Sorry about this.
It looks like you are on the right track with using the equations for motion and force. However, there are a few things that may be causing your issue with getting a negative answer.
First, when using the equation a = (V^2 - Vo^2) / 2x, make sure to use the square of the initial velocity (Vo^2) and not just the initial velocity (Vo). So, the equation should be a = (V^2 - Vo^2) / 2x. This may be causing your answer to be negative.
Second, when plugging in the values for mass and acceleration into the equation net force = m(a), make sure to use the correct units. In this case, the mass should be in kilograms and the acceleration should be in meters per second squared. If you are using different units, this could also be causing your answer to be negative.
Lastly, it is important to consider the direction of the force. In this problem, the car is coming to a halt, which means the net force is acting in the opposite direction of the car's motion. This means the net force should be negative, as it is acting in the negative direction.
Overall, it is important to double check your equations and units to make sure everything is correct. If you are still having trouble, try breaking the problem down into smaller steps and solving each step separately. Good luck!
  • · Replies 56 ·
