Filters in closed-loop control
by Riscilla
Tags: closedloop, control, filters
Riscilla
Riscilla is offline
#1
Oct19-10, 06:30 AM
P: 18
Hi friends,
I have a question regarding the use of filters in closed-loop control systems. Very often in a system like that there is noise from the sensor, and we have to put a filter after the sensor to eliminate the noise. However, all filters produce a phase shift as well as an amplitude attenuation into the measured signal, therefore the signal we get is already distorted. My question is that how could we control the system in these circumstances?
To make things clearer, I will give an example: Suppose I intend to setup a digital control system with a update frequency (sample rate) of 1 (kHz). But the measured signal is very noisy, so I have to use a filter to reduce the noise. After several tries, I come up with a filter which has a -3db of 200 (Hz). With this sensor, all noises are removed, however, there are also a lot of phase shift and amplitude attenuation. Can we still control the system with that filter?
Thank you for reading my question. Any answer would be very appreciated.
Regards,
Riscilla
Phys.Org News Partner Engineering news on Phys.org
SensaBubble: It's a bubble, but not as we know it (w/ video)
WSU innovation improves drowsy driver detection
Faster computation of electromagnetic interference on an electronic circuit board
schip666!
schip666! is offline
#2
Oct19-10, 01:03 PM
P: 595
It all depends on the rest of the system's time constants and response requirements. A simple motor speed control updated every .01 sec is probably pretty good, but other applications may need quicker response or more accurate tracking.
crunchman
crunchman is offline
#3
Oct22-10, 06:44 AM
P: 2
i deleted original post. i did not carefully read your question.
the problem is in the sensor. i think you only need to add a compensator to correct phase shift. there should be a chapter on compensator design in control systems books.
another way is to mathematically apply filtering/ compensation/ control by programming a microcontroller or interfacing with a scientific package (scilab, matlab, labview).
Register to reply
Related Discussions
Closed wire loop Introductory Physics Homework 6
closed loop of classical string Classical Physics 2
Matlab Control Loop Math & Science Software 0
integral along a closed loop Calculus & Beyond Homework 2
Closed Loop General Astronomy 11
