Underdamped System Response: Solving with Convolution Integral | Homework Help
The discussion focuses on solving the underdamped system response described by the differential equation x'' + 2ζωnx' + ωn2x = us(t) using the convolution integral. The unit step function us(t) is defined with zero initial conditions, leading to distinct behaviors for t < 0 and t > 0. The solution involves determining the impulse response h(t) of the system, which is derived from the differential equation with the Dirac delta function as the forcing function, and then convolving h(t) with u(t) to obtain the total response.
  • Understanding of underdamped systems and damping ratios (ζ)
  • Familiarity with convolution integrals in the context of differential equations
  • Knowledge of impulse response functions in linear systems
  • Basic concepts of Laplace transforms and their applications
  • Study the derivation of impulse response functions for second-order linear systems
  • Learn how to apply the convolution integral in solving differential equations
  • Explore the use of Laplace transforms to analyze underdamped system responses
  • Investigate the effects of varying the damping ratio (ζ) on system behavior
Students in engineering or physics, particularly those studying control systems, signal processing, or differential equations, will benefit from this discussion.
ganondorf29
[tex] <br /> x'' + 2\zeta \omega_{n} x' + \omega_{n}^2 x = u_{s}(t) <br /> [/tex]
zeta is underdamped and [tex]u_{s}(t)[/tex] is the unit step function and [tex]\omega_n[/tex] is the natural frequency and there are zero initial conditions. Find the total response via the convolution integral.
[tex] <br /> u_{s}(t)=\left\{\begin{array}{cc}0,&\mbox{ if }<br /> t\leq 0\\1, & \mbox{ if } t>0\end{array}\right.<br /> [/tex]
Since there are two time intervals there are two different behaviors
When t < 0
Because there is no forcing term the response is a free response to an under damped system.
[tex] <br /> x(t) = exp(-\zeta \omega_{n}) * cos(\omega_{d} t)<br /> [/tex]
When t > 0
I'm not sure how to use the convolution integral to find the response
When t < 0
You're not taking into account the initial conditions.
When t > 0
The idea is to find the impulse response h(t) of the system, which is the solution to the differential equation where the forcing function is the Dirac delta function and which satisfies the initial conditions. Then convolve h(t) with the given forcing function, u(t), to find the total system response.
  • · Replies 16 ·
14K
27K
