Solving Frictional Force of Sand on Conveyor Belt
  • Thread starter Thread starter abcd8989
    Friction
The frictional force acting on sand poured onto a conveyor belt moving at a constant speed of 4 m/s can be calculated using the formula F_f = v_conveyor * (dm/dt). Given that sand is added at a rate of 25 kg/s, the frictional force is determined to be 100 N. The initial approach using impulse was incorrect, as it did not account for the continuous mass addition and the lack of acceleration of the conveyor belt.
  • Understanding of Newton's laws of motion
  • Familiarity with the concept of momentum
  • Knowledge of kinetic friction principles
  • Basic algebra for manipulating equations
  • Study the principles of momentum and impulse in physics
  • Learn about kinetic friction and its applications in real-world scenarios
  • Explore advanced topics in dynamics, including forces on moving systems
  • Review examples of mass flow rates and their impact on force calculations
Students studying physics, particularly those focusing on mechanics, as well as engineers and professionals involved in material handling and conveyor systems.
abcd8989
Sand is poured onto a converyor belt at a constant rate of 25kg/s. The belt keeps moving horizontally at a constant speed of 4m/s.
What is the fricional force acting on the sand?
According to the solution, the answer can be calucated using "impulse":
Taking right hand side be positive.
friction =[ 25 X (+4) - 0 ] /1
= 100 N
I don't understand why such approach works. The teacher said that the sand experience kinetic friction at the instant when it touches the belt, and that some time(though very small) is required for the sand to accelerate from 0m/s to 4m/s. However, I don't know why the above equation can solve the problem. Why the time of impulse can be regarded as 1? It is not given that the sand accelerates from 0m/s to 4m/s in 1 second.
You're right, this is a bogus solution. The problem really ought to be done with the true definition of F.
[tex]\Sum F_{ext} = \frac{dp}{dt} = m \frac{dv}{dt} + v \frac{dm}{dt}[/tex]
where p is momentum.
So there is no acceleration from the conveyer belt, which makes dv/dt=0. There is however mass constantly being added to the conveyer belt at 25kg/s.
[tex]F_f=v_{conveyer}\frac{dm}{dt}[/tex]
so F_f = 4m/s*25kg/s
  • · Replies 19 ·
  • · Replies 63 ·
10K
  • · Replies 27 ·
