Find the direction and magnitude of the third force
The problem involves an object acted upon by three forces while moving with constant velocity. Two forces are specified: one with a magnitude of 6.5 N in the positive x direction and another with a magnitude of 4.4 N in the negative y direction. The task is to determine the direction and magnitude of the third force.
  • Participants discuss the implications of constant velocity, suggesting that the resultant force must be zero. Some propose sketching the forces to visualize the third force's direction and magnitude. Others question the calculations regarding the total force needed for equilibrium.
The discussion is ongoing, with participants providing hints and guidance without reaching a consensus. There are differing interpretations of the third force's magnitude and direction, and some participants are encouraged to clarify their understanding through visual representation.
Participants are working under the assumption that the object experiences no net force due to its constant velocity, which is a key aspect of the problem. There may be constraints related to the specifics of the forces involved and the need for accurate vector representation.
dg_5021
Can someone help me with this problem am clueless.
An object acted on by three forces moves with constant velocity. One force acting on the object is in the positive x direction and has a magnitude of 6.5N; a second force has a magnitude of 4.4N and points in the negative Y direction. Find the direction and magnitude of the third force acting on the object?
Since the velocity of the object is constant, the resultance of the three forces acting on the object is zero.
If there would be a resulting force there would have been an acceleration. F=m*a remember?
If you make a scetch with a dot representing the object and the 2 known forces as vectors you can see approximately where the third force would be and how big it is.
Hopefully you can calculate it as well with these hints.
Thanks Jovaro for your help
so according to my understanding the third force has to be a total of 10.9 N in order for the resulant to be zero?and the direction is y positive and x negative
Not really, take a look at the drawing. That should make it clear.
  • · Replies 16 ·
  • · Replies 18 ·
  • · Replies 21 ·
