| New Reply |
Ok to use MOSFET body diode as flyback protection? |
Share Thread | Thread Tools |
| Oct20-10, 09:42 PM | #1 |
Hello,
I am designing a motor controller, and I was curious about the MOSFETs I'm using that have an internal body diode zener for Vds protection that is common in a lot of datasheets. I am switching the coils of the inductor with these MOSFETs, and I would like to know if its unwise to assume to use the internal zener diode of the MOSFET as my flyback diode when I am switching the inductor. The part I'm using is IRFP3206 and I see the max pulsed current is 840 Amps for the FET's diode, and I can do the calculations to approximate the flyback current, so I think it is ok to use. But, I just am cautious to use the internal diode for a specific function, when it seems like it is put in more to protect the FET junctions as a general purpose protection. Is this done in practice? |
| Oct21-10, 09:24 AM | #2 |
I'm not sure if it's normal practice or not (I'd guess not), but with a forward voltage of 1.3V you're wasting power compared to an external Schottky for instance. Also, the reverse recovery time of the internal diode is typically not as fast as it will be with an external diode. Hard to tell if these are issues with the limited information you provided. Good luck.
| Oct21-10, 04:41 PM | #3 |
| Oct21-10, 05:57 PM | #4 |
Recognitions:
When you switch an inductive load with a FET or transistor, the main spike is positive going, so a diode across the FET isn't going to help unless it is a Zener diode.
The diode needs to be a fast one and across the load with the anode connected to the drain of the FET. The diode in Mosfets is usually shown as a Zener, but this would break down at some fairly high voltage (maybe 50 volts or so), so the power dissipated would be quite high and it would add to the heating of the FET. |
| New Reply |
| Thread Tools | |
Similar Threads for: Ok to use MOSFET body diode as flyback protection?
| What size inductance for a flyback transformer? | Electrical Engineering | 0 | ||
| Television Flyback rewiring | Electrical Engineering | 6 | ||
| Flyback Diode Implementation/Sizing w/ Relays/Switches | Electrical Engineering | 7 | ||
| diode protection circuit help | Electrical Engineering | 3 | ||
| Flyback Transformer (LOPT) | General Discussion | 1 | ||
