How Do You Calculate the Initial Velocity in Horizontal Projectile Motion?
The discussion revolves around a physics problem involving horizontal projectile motion, specifically calculating the initial velocity required for a ball thrown from a height of 10 meters to reach a target 8 meters away. The problem includes multiple parts, with the original poster expressing difficulty with the first part of the question.
  • The original poster attempts to relate the problem to a parabolic trajectory and questions the method used to find the horizontal component of velocity. Some participants suggest separating the horizontal and vertical motions and inquire about the relevant kinematic equations.
The discussion is ongoing, with participants providing guidance on how to approach the problem. There is an acknowledgment of the original poster's confusion regarding the application of the range equation, and some clarification has been offered regarding the nature of horizontal projectile motion.
The original poster indicates that they understand parts (b) and (c) of the problem but are struggling with part (a). There is a mention of using a range equation that may not be applicable in this scenario, highlighting potential misconceptions about the problem setup.
Physics_Newbie
Well, this is my first of most likely many posts. Here goes the homework problem:
An Engineering student wants to throw a ball out of a third story window (10 m off the ground) onto a target on the ground placed 8.0m away from the building. (a) If the student throws the ball horizontally, with what velocity must the ball be throw? (b) What must the velocity of the ball be if it's thrown up at an elevation angle of 29degrees? (c) What is the ball's time of flight in case of (b)?
I understand how to do both parts (b) & (c) but part (a) is giving me a bit of trouble.
The only way that I've figured out how to do part (a) is to make a parabola out of the figure then figure out the horizontal component at the max height (of 10m). This seems to be a roundabout way of completing the problem.
So, if anyone has a suggestion please share.
Thank You
Welcome to PF!
Problem a is a simpler version of problem b! So I don't understand how you could do b, but not a. Show what you've done.
One way to do projectile motion problems is to treat the x and y motions separately. What are the relevant kinematic equations?
Well, what's throwing me off is that theta=0 degrees @ T=0
So, when I plug in that value into the range equation it's spitting back 8(-9.8m/s^2)= (Vr)^2 x sine(2*0). This is obviously giving me the wrong answer since 8 is not equal to zero.
I'll print out the instruction sheet for the LaTeX script so I can start typing these out more clearly for everyone involved.
That range equation only applies on level ground, not when tossing a ball out the window. Forget it.
Set up the kinematic equations for vertical motion (uniform acceleration) and horizontal motion (constant speed). Hint: when you toss the ball horizontally, its vertical component of velocity is zero.
Ah, that makes sense.
Thanks for your patience & help.
  • · Replies 21 ·
  • · Replies 18 ·
