| New Reply |
Cartesian equation for the Magnetic field resulting from a single current loop? |
Share Thread | Thread Tools |
| Oct22-10, 08:00 AM | #1 |
Hello
I am carrying out some analysis on the magnetic field generated over a 3D region by a single current loop. The present form of the equations is in cylindrical coordinates and is as follows [tex]\vec{B}[/tex]={Brc,0,Bz} There is no angular component in this present from. Note: The following website contains the formulas in question: http://www.netdenizen.com/emagnet/of...oopoffaxis.htm My question is as follows. How could one convert a complex cylindrical equation such as this to Cartesian coordinates? The main aim of this is to plot the fields in Matlab, if the equations were in cartesian form it would simply greatly my analysis. The main problem I seem to encounter is that since there is no angle component, using conversions such as x=r*cos(theta) and y=r*sin(theta) do n0t seem to make sense as it would imply that there is only an x component and no y component. I tried using Mathematica to convert the equations using the ConvertToCartesian command to no avail. Any help with this problem would be greatly appreciated. Regards Kilian |
| Oct22-10, 11:41 AM | #2 |
Recognitions:
Just use [tex]r=\sqrt{x^2 + y^2}[/tex].
| Oct22-10, 01:14 PM | #3 |
Thanks for the reply, I had thought of using that but i still have the problem where there is no y component of the magnetic field.
In other words converting B(rc,phi,z)=(Brc(rc,theta,z),0,Bz(rc,theta,z)) would result in B(x,y,z)=(Bx(x,y,z),0,Bz(x,y,z)). The By(x,y,z) component is zero, is this correct? Or is there a way to expand the rc unit vector into x and y parts? |
| Oct23-10, 01:06 AM | #4 |
The conversion between cylindrical and Cartesian components goes like
![]() This is from http://www.engin.brown.edu/courses/e.../Vectors6a.htm |
| New Reply |
| Tags |
| cartesian, current loop, magnetic field, matlab |
| Thread Tools | |
Similar Threads for: Cartesian equation for the Magnetic field resulting from a single current loop?
| Current Loop Magnetic Field | Introductory Physics Homework | 9 | ||
| Magnetic field due to current loop | Introductory Physics Homework | 8 | ||
| Magnetic Field Current Loop | Introductory Physics Homework | 1 | ||
| Interaction of a Current Loop with a Magnetic Field | Introductory Physics Homework | 2 | ||
| Current loop + perpendicular current : magnetic field? | Advanced Physics Homework | 1 | ||
