What is Stronger Steel Square Hollow Section or steel Circular Hollow Section
The discussion centers on the strength comparison between a 33.7mm diameter x 4mm thickness Circular Hollow Section (CHS) and a 40mm x 40mm x 2.5mm Square Hollow Section (SHS) for chassis construction. Both sections weigh approximately the same per meter, prompting a detailed analysis of their compressional and tensile strengths. Key considerations include the axis of load application and the intended use, particularly whether the structure will support human weight.
  • Understanding of structural engineering principles
  • Knowledge of material properties, specifically steel
  • Familiarity with load-bearing calculations
  • Experience with chassis design and construction
  • Research the compressive and tensile strength properties of steel CHS and SHS
  • Explore the impact of load direction on structural integrity
  • Learn about the design considerations for chassis construction
  • Investigate relevant engineering standards for safety and performance
Engineers, chassis designers, and construction professionals seeking to optimize material selection for strength and safety in structural applications.
mclaughlin684
Hey there, I am going to by building a chassis and i am wanting to find out if 33.7mm dia X 4mm thickness circular hollow section or 40mm X 40mm X 2.5mm Square Hollow Section is stronger these two weight around the same per meter
thanks Ian
Are you talking about compressional strength? Tensile strength? Along which axis?
Is this intended to support people?
  • · Replies 19 ·
18K
10K
19K
19K
