Nonuniform Circular Motion: The Top of the Loop
The discussion focuses on the dynamics of nonuniform circular motion, specifically analyzing the conditions under which a ball maintains contact with a loop-the-loop. It establishes that at the top of the loop, the gravitational force (mg) equals the centripetal force (Fc) when the normal force (N) is zero, indicating a minimum velocity required to stay in contact. If the ball's speed drops below this threshold, it loses contact and follows a parabolic trajectory. This principle is similarly applied to a go-cart navigating over a hill, where exceeding a certain speed results in the loss of contact with the ground.
  • Understanding of Newton's laws of motion
  • Familiarity with concepts of centripetal force and gravitational force
  • Knowledge of free body diagrams in physics
  • Basic calculus for deriving velocity equations
  • Study the derivation of the minimum velocity for circular motion in loops
  • Learn about the effects of varying speeds on centripetal force
  • Explore the physics of projectile motion following loss of contact
  • Investigate real-world applications of nonuniform circular motion in amusement park rides
Physics students, educators, and anyone interested in understanding the principles of circular motion and dynamics in mechanical systems.
L'Arrogant
If a ball is going through a loop-the-loop, at the top, if mg=m(v^2/r), it will continue around the loop. If mg>Fc, it will fall. In the first case, when mg=Fc, the normal force on the ball from the metal of the loop is 0. This is easy enough to see when the equation from the free body diagram of the ball is rearranged (if N=mg-Fc, and the latter two are equal, Normal is zero); I don't understand why this is, though. Rereading it, my question seems vague. To restate: the fact that N depends on mg and Fc makes sense, but it doesn't make sense to me that the fact that N=0 means that the ball is at some minimum velocity. The first relationship follows directly from the free body diagram. The second doesn't follow so clearly. Or does it?
Similarly, a go cart riding over a hill can go a maximum speed before it leaves the ground entirely. Same thing: N=0, v=(gr)^1/2. Is the fact that N=0 a result of it leaving the ground, or the cause? My professor wrote that N=mg-Fc=0 when contact lost.
Thanks for taking the time to read my question.
N = 0 just specifies the condition that the ball is about to lose contact with the loop. For high enough speeds, the ball will be pressed against the loop and thus N > 0. The minimum speed for maintaining contact with the loop can be determined from setting N = 0. If the speed drops below that minimum speed, the net force on the ball (which is now just mg) becomes too much--the ball is pulled away from its circular path and becomes a free projectile following a parabolic path.
The same idea but in reverse for the cart going over the hill. If the cart goes too fast, the force of gravity (mg) is not enough to hold the motion in its circular path over the hill, so the cart shoots off into the air as a free projectile following a parabolic path.
  • · Replies 19 ·
  • · Replies 21 ·
