Understanding Time Dilation in Frames of Reference: A Basic Question
The discussion revolves around the concept of time dilation in special relativity, specifically examining the implications of two frames of reference moving relative to each other. Participants explore the calculations and interpretations of time intervals measured by observers in different frames, questioning the consistency of their findings.
  • One participant describes a scenario with two clocks in different frames, calculating time intervals based on the time dilation factor \(\gamma \equiv 2\), and questions the apparent contradiction in the measurements of the two clocks.
  • Another participant suggests that the chosen time intervals may be arbitrary and potentially confusing, emphasizing that each frame observes the other's clock running slow by the same factor.
  • A third participant proposes using Lorentz transformations to clarify the situation, noting that simultaneity is frame-dependent and that the clocks are not compared at the same location when their readings are taken.
  • One participant calculates the velocity corresponding to \(\gamma \equiv 2\) and attempts to apply Lorentz transformations, expressing confusion over the results.
  • Another participant challenges the velocity calculation, suggesting a potential error in the interpretation of the speed relative to the speed of light.
  • A later reply acknowledges typos in the previous calculations and corrects the velocity, confirming that it is less than the speed of light.
Participants express differing interpretations of the time dilation results and the implications of simultaneity in different frames. There is no consensus on the resolution of the apparent contradictions presented in the calculations.
Participants highlight the importance of simultaneity and spatial positioning when comparing time readings from different frames. The discussion reveals potential limitations in the assumptions made regarding the measurements and the application of Lorentz transformations.
abcd2357
Suppose we have two frames of reference, frame A and frame B, which move past each other with a velocity such that [tex]\gamma \equiv 2[/tex]. In frame A is clock A and in frame B is clock B.
In frame A, clock A is at rest and clock B is speeding past. As a result of time dilation, when an observer in frame A measures clock A as having an interval of [tex]5 s[/tex], this observer measures clock B as having an interval of [tex]5 / 2 = 2.5 s[/tex]. Furthermore, an observer in frame B measures clock B as having an interval of [tex]2.5 s[/tex].
In frame B, clock B is at rest and clock A is speeding past. As a result of time dilation, when an observer in frame B measures clock B as having an interval of [tex]2.5 s[/tex], this observer measures clock A as having an interval of [tex]2.5 / 2 = 1.25 s[/tex]. Furthermore, an observer in frame A measures clock A as having an interval of [tex]1.25 s[/tex].
This seems to imply that when an observer in frame B measures clock B as having an interval of [tex]2.5 s[/tex], an observer in frame A measures clock A as having an interval of both [tex]5 s[/tex] and [tex]1.25 s[/tex].
Where did I go wrong?
Is this homework, it seems like a 'trick' setup? The chosen intervals are completely arbitrary and not relevant to any physics, but they were chosen in such a way that they could confuse. Thing to remember is that each frame observes the other frame's clock going slow by the same factor.
Try it this way. Say both clocks pass each other at x = x' = 0 and t = t' = 0. The primed coordinates refer to the frame that clock B is at rest in. Work out what the required velocity v should be, to get the required gamma factor and then work out how far B travels in 5 seconds to obtain x when t=5. You will now have values for v, x and t to plug into the Lorentz transformation equations to obtain what the time t' is according to b. You can then use the reverse transformation to see how things look from B's frame. If you have not used the Lorentz transformations before, this is a good place to start. Drawing two space-time diagrams from the point of view of each observer, might help you see what is happening too.
Briefly, the clocks are not at the same place when they are compared and when B says his clock reading of 2.5s is simultaneous with A's clock reading of 1.25s, the observer in A will not agree that those events are simultaneous in his frame. When the observer in frame A says his clock reads 5 seconds simultaneously with clock B reading 2.5 seconds, the observer in frame B will not agree that those events are simultaneous in his frame.
So [tex]\gamma \equiv 2 \implies v = \frac{\sqrt{3}}{2} c[/tex].
We have: [tex]t' = \gamma (t - \frac{x v}{c^2})[/tex] and [tex]t = \gamma (t' + \frac{x' v}{c^2})[/tex].
It follows that [tex]t' = 2 (5 - \frac{\frac{\sqrt{3}}{2} c 5 \frac{\sqrt{3}}{2} c}{c^2}) = 2.5[/tex]. But then going in reverse, [tex]t = 2 (2.5 + \frac{- \frac{\sqrt{3}}{2} c 2.5 \frac{\sqrt{3}}{2} c}{c^2}) = 1.25[/tex].
What's wrong with that?
I think v=1/sqrt(3).
You've got v/c > 1, haven't you ?
Sorry, there were some serious typos/latex issues in that last post. Gamma should have been 2, not 3. Now v=(sqrt(3)/2)*c, which gives v/c < 1. I edited the post, so the issues should now be corrected.
  • · Replies 88 ·
  • · Replies 22 ·
  • · Replies 33 ·
  • · Replies 36 ·
  • · Replies 54 ·
  • · Replies 20 ·
  • · Replies 16 ·
