Velocity of a Proton in a Capacitor
The discussion centers on calculating the velocity of a proton fired from the negative plate of a capacitor charged to 1000 Volts. The user applies the conservation of energy principle, utilizing equations such as 1/2mv² = (KeQq)/r and V = U/Q. However, the user struggles with missing variables, specifically the charge on the capacitor and the distance between the plates, which are essential for solving the problem. The key takeaway is that knowing the voltage and the charge of the proton allows for the determination of the kinetic energy imparted to the proton.
  • Understanding of conservation of energy principles in physics
  • Familiarity with capacitor voltage equations
  • Knowledge of kinetic energy formulas
  • Basic grasp of electrostatic forces and charge interactions
  • Explore the relationship between voltage, charge, and energy in capacitors
  • Study the derivation of kinetic energy equations in particle motion
  • Learn about electric field strength and its effect on charged particles
  • Investigate the concept of potential difference and its role in particle acceleration
Students studying physics, particularly those focusing on electromagnetism and energy conservation, as well as educators seeking to clarify concepts related to capacitors and particle dynamics.
joshszman09
(1). Homework Statement
Suppose a proton is fired from the negative plate of a capacitor charged up to 1000 Volts. How fast must it be traveling to reach the other side?(2) Relevant equations
Okay, so I figured that this would be a conservation of energy problem and used: 1/2mv2 = (KeQq)/r
I think this would work, but it requires that you know both the charge on the capacitor and the distance between the plates which is not given. I am really stuck and could use some help. I just need to be pushed in the right direction and hinted towards what to do. I have literally tried everything I know about voltage and capacitors and just can't get it. If you need and more info/have questions just let me know. Thanks in advance!
3. Attempt at Solution
There isn't much to put here except a few of the equations I tried using.
I know that V = U/Q and that U= (KQq)/r and so I came up with V = (Kq)/r and tried solving for r(distance between the plates), but I got a really small number, r = 1.44E^-12. Even if that is right, I still can't think of a way to solve for the charge, Q, on the capacitor and plug the numbers into the equation I wrote in (2)
If you are given the voltage, and you know the charge on the proton, then you should have the energy that the field is supplying to the proton. This energy is converted into the kinetic energy (1/2)mv2.
  • · Replies 18 ·
