Contraction effects at relativistic velocities
The discussion revolves around the effects of length contraction at relativistic velocities, particularly focusing on whether dimensions perpendicular to the direction of motion experience contraction. Participants explore various scenarios involving objects and ships moving at relativistic speeds, raising questions about simultaneity and the implications of relativistic effects on measurements.
  • One participant questions whether the perpendicular length of a rod traveling at relativistic speeds contracts, suggesting a need for clarity on the effects of velocity on dimensions.
  • Another participant presents a similar scenario involving two ships traveling parallel to each other, asking if the distance between them is subject to contraction.
  • Some participants assert that length contraction only occurs in the direction of motion, indicating that dimensions perpendicular to motion do not contract.
  • A participant introduces a hypothetical scenario involving a ship and guns on a planet, questioning whether bullets would hit the ship based on the timing of their firing as perceived from different frames of reference.
  • There is a discussion about simultaneity, with participants debating whether events that are simultaneous in one frame are also simultaneous in another, leading to differing conclusions about the timing of events as perceived by observers in different frames.
  • One participant references the Bell's Spaceship Paradox to illustrate how observers in different frames perceive distances and events differently, although this is contested by others who focus on the specific scenario of guns firing at a ship.
Participants generally disagree on the implications of length contraction and simultaneity, with multiple competing views presented. The discussion remains unresolved regarding the effects of relativistic velocities on perpendicular dimensions and the interpretation of simultaneity across different frames.
Participants reference various scenarios and thought experiments that highlight the complexities of relativistic effects, including the need for careful consideration of frame of reference and the nature of simultaneity. Some assumptions about the conditions of the scenarios are not fully articulated, leading to potential ambiguities in the discussion.
asprin
Just an issue I want to be absolutely clear about.
Scenario,
WE propell a rod of iron with a dimensions of 100 meters *1 meters through space with the 100 meter length perpedicular to the direction of velocity.
So the rod is traveling width edge forward. ( perpedicular to direction)
the question is :
Does the perpendicular length of our rod contract?
( if the velocity length is 1 meter and our width is 100 meters as per direction)
And also
Is there a table that is available to give contraction results vs veocity somewhere on the Net?
say contraction vs Earth meter at velocities like 0.1c, 0.2c, 0.3c etc etc
any help would be appreciated
another version of the same question
If we have two ships both traveling parallel to each other at relativistic velocities is the distance of separation subject to contraction?
I don't think so not with both ships at the same line perpendicular to motion, because they are not moving at all relative to each other and the horizontal distance will not shrink no matter how fast they go.
length contraction formula
the question is :
Assuming you mean the length perpendicular to the motion (the "100 meter" length), then no. Length contraction only occurs in the direction of motion.
No need for a table, the formula is simple. Let [tex]L_0[/tex] be the length of an object in its own (rest) frame; then L will be the length of the object measured from a frame in which the object is moving at speed v parallel to its length:
[tex]L = L_0 \sqrt{1 - v^2/c^2}[/tex]
This is relative to the frame which sees the rod moving with velocity v.
Thanks, selfAdjoint. I think my wording was a bit convoluted!
ok let's say there is a ship 100ft long moving at .90c. a planet perpendicular has guns 101ft apart at rest. the guns line of fire are parrallel to each other. the planet plans it out so that the ship will be in between the bullets when the ship flies past the planet. would the bullets hit the ship or not?
I'm going to assume that you mean for the guns to fire simultaneously according to the planet.
The answer is that the bullets will miss the ship, according to both the ship and the planet. From the ships view, the guns do not fire simultaneously.
no i mean simultaneously according to the ship
If they are fired simultaneously according to the ship, then the planet can't plan it out such that the ship is between the bullets when the ship flies past the planet. In that case, according to the planet, the guns do not fire simultaneously. For instance, if from the ship frame, the bullets hit the ship while being fired simultaneously, then from the planet frame, the guns will fire in a staggered order timed such that the bullets each hit the ship
why is it not simultaneous from both frames? if it is simultaneous from the planet then the ship sees that farthest gun shooting off first. right?
With regards to your first question - No. For the reason why please see the bottom section of - http://www.geocities.com/physics_world/sr/lorentz_contraction.htm
As per the question above - Assume that the rockets are identical and that they fire their engines at a constant rate as measured in an instantaneous rest frame. Let them start from rest each lying on the x-axis, one in front of the other. Then let an observer in the inertial frame measure the distance between them. The inertial observer will detect no change in distance between the two rockets. Not let either of the observers who are at rest in the rockets measure the distance. Each observer will measure the distance increasing. This is known as Bell's Spaceship Paradox. See - http://math.ucr.edu/home/baez/physics/Relativity/SR/spaceship_puzzle.html
The reason has to do with gravitational time dilation and Lorentz contraction.
The observer in the trailing rocket ship can think of himself as being at rest in a uniform gravitational field. He's firing his engines so as to neither rise nor fall. This observer sees the the other rocket ship higher in the gravitational field. However, due to gravitational time dilation, the bottom observer will see the rocket as firing his engines at a rate which is faster than his and therefore he gains height.
Pete
there is no rocket trailing the other. there are two guns, parallel to each other, and firing perpendicular to the line of movement of the ship.
l=bullets path
-=ships path
s=space
ssssssssssslsssslssssssssssss
-----------lShipl------------
From the viewpoint of the ship, the gun in the rear fires first.
the animation did not work for me.
ssssssssss^ssss^sssssssssss
-----------lShipl------------>
ssssssssssAssssBsssssssssss
B would shoot first right?
i got the animation to work. the ship that is moving in both animations looks like it is trying to out run the light. how can they see the explosion before they see the light of the flash. they could not possibly see the explosion until they see the light from the explosion.
It's not that observer two sees the explosions happen before he sees the flashes, it is when observer 2 determines the explosions had to occur in order for him to see the flashes at the same time. Example: If a light flash originates 1 light sec from me, and I see that flash when my clock reads 12:00:01, I know that the flash started when my clock read 12:00:00
And if the flash originated 2 light secs from me and I see the flash at 12:00:01, then it originated when my clock read 11:59:59, Thus, if I see two flashes at the same time and one originated further from me, then the further explosion occurred before the closer.
Also:
Assume you have observers at the actuators in the same frame as observer two. They have clocks which are synchronized with each other and a clock carried by observer 2.
The blue observer stops his clock when he is opposite the other blue marker (We can assume that he passes so closely to that marker that we don't have to consider light signal delay.)
The green observer does the same when he passes the green marker.
Thus each observer has a clock that records when the explosion from his marker occurred. If you were to bring the clocks together you will find that that the green observer's clock will read less than the blue observer's, and thus according to synchonized clocks sharing the same frame as observer 2, the explosions did not occur at the same time.
would time dilation come into effect?
Time dilation needs to be considered when we are comparing the clock rates between frames. Such as the rate that observer 1 would determine for frame 2's clocks, or the rate that frame 1's clocks would have as measured by observer 2. In this instance, we are only concerned with when the events occurred in each frame according to its own clocks.
As Janus points out, it depends on what you wish to know. Referring to your example of the ship flying past the planet with the guns: If all you want to know is "According to the ship, which gun fires first" then you need only consider the desynchronization of the planet clocks as seen from the ship (the "relativity of simultaneity"). But if you want to know "According to the ship, how much time passes between the firing of the two guns" then you need to consider time dilation as well.
ok then from the view of the ship, if we set a ship off from the planet instead of guns then the ship we just launched would look like it took off crooked?
because both side of the ship would be taking off at simualtanousley from the view of the planet.
what would happen from both views if we did not have the lorenz contraction?
what causes this non-simultaneosness? Just the fact that light moves at a limited speed and therefore depending on what direction you are going the light has less space to travel, but more going in a diff. direction? Or something to that effect. Meaning, is the non-simultaneosness just the cause of a the way the information travels or is there something else to it?
length contraction in the two different frames cause the non-simultaneosness in the frames. look at the animation on the first page. since each frame sees the other as being shorter they have different times as to when each pass each other.
But length contraction itself is just a cause of non-simultaneosness - I think. If not, then what's the cause of length contraction?
but basically in order to have light to be constant for all observers we need to alter time and space to make that happen.
No, "we" don't do it at all. It's just what happens.
  • · Replies 60 ·
  • · Replies 42 ·
  • · Replies 55 ·
10K
  • · Replies 78 ·
  • · Replies 17 ·
9K
