Simulation of the sun's effect on temperature change on the ground surface
To simulate the temperature change of a 10 square meter asphalt patch, the initial temperature is set at 20 degrees Celsius, assuming thermal equilibrium with the environment. The radiant intensity from the sun is approximated at 250 W/m², leading to a total energy input of 2500 W for the asphalt surface. However, this calculation results in an unexpectedly high temperature change, indicating a potential error in the approach. It's important to consider that the sun's intensity directly overhead can be four times higher than the average value, affecting the calculations. Understanding the differences in thermal radiation compared to black body radiation is crucial for accurate temperature estimations.
hersh37
Hi,
I am working on simulating the change in temperature over time for the ground, given different material types. For instance, I'm considering an asphalt patch of ground say 10 square meters in area. For now, I'm willing to ignore atmospheric effects like rain, wind, and varying sun angle. I assume for now that the sun is directly overhead.
If the ambient temperature of above the ground is 20 degrees Celsius, and I assume the asphalt is in thermal equilibrium with the environment at time t=0, then it is also at 20 degrees Celsius. How would I go about determining the aspalt's new temperature at time t=1?
I'm probably missing something, but I see that the radiant energy from the sun will act on the asphalt patch, and excite its molecules, which will cause it to rise in temperature, however is there a way to calculate how much (even approximate)?
According to sources the sun's radiant intensity at the Earth surface can be approximated to about 250 W/m^2. For the 10 square meter aspalt surface, this would be 2500 W then. If I use this is as the value of \Delta Q in the equation \Delta Q = c \DeltaT, with c=0.93 for aspalt, this gives me an unbelievably high value for the change in temperature.
I know I'm doing something wrong here. Any help is greatly appreciated. Thanks :)
Science news on Phys.org
The asphalt is going to radiate the thermal energy. You will want to know how much its radiation differs than black body radiation.
hersh37 said:
Hi,
This is an average of the irradiaton over the whole globe, including the night side and places where the sun is far from the zenith.
With the sun directly overhead, it's 4 times as high. This is because the Earth only catches
the sunlight in a disk with an aria of pi R^2 where R is the radius of
the earth, but the surface of the Earth is 4 pi R^2, so the average is only
(1/4) of the maximum
Thread 'Thermo Hydrodynamic Effect'
Vídeo: The footage was filmed in real time. The rotor takes advantage of the thermal agitation of the water. The agitation is uniform, so the resultant is zero. When the aluminum cylinders containing frozen water are immersed in the water, about 30% of their surface is in contact with the water, and the rest is thermally insulated by styrofoam. This creates an imbalance in the agitation: the cold side of the water "shrinks," so that the hot side pushes the cylinders toward the cold...
