| New Reply |
Circuit for Hall effect sensor |
Share Thread | Thread Tools |
| Oct26-10, 07:39 AM | #1 |
Hello
I recently bought a linear Hall effect sensor for measuring current, but I don't know how to make the circuit to measure the current, could anybody help me with this? Please tell me the circuit. By the way, I use the linear Hall effect sensor CSLA2EL by Honeywell. Thank you very much! |
| Oct26-10, 11:55 AM | #2 |
Wow, that's not easy...the first google link I got was labeled "datasheet" but I couldn't find any electrical connection information on it.
But I found a bunch of other datasheets here: http://www.datasheets.org.uk/CSLA2EL-datasheet.html and one has a pinout buried deeply in the noise. Now I forget which link I clicked and followed and interpreted, but you should be able to find it too... It looks like they take a power supply of 8-16v and put out a voltage that is proportional to the current in the loop. |
| Oct26-10, 12:35 PM | #3 |
I think this is the datasheet for the Hall effect sensor in the unit. The calibration is in terms of the Gauss field in the toroid gap.
http://sccatalog.honeywell.com/pdbdo...s/91ss12-2.pdf See attached pdf for some info on electrical characteristics of current sensor Hall effect holder toroid. [added] The performance specs for the Hall effect sensor are for operating with a 12 volt dc input. I suggest using a 7812 3-pin regulator. The Hall effect sensor output is an ac output for an ac current input. The null output offset voltage for zero current input is 6 volts ± 0.6 volts. The output appears to be an npn transistor current-sourcing emitter. Bob S |
| Aug24-12, 02:32 PM | #4 |
This pdf (CS Series Linear Current Sensor Holder Assemblies) is really useful.
Thanx bob, http://www.halleffectsensor.org/ |
| Aug24-12, 04:01 PM | #5 |
Mentor
| New Reply |
| Tags |
| circuit, current, hall effect, measurement, sensor |
| Thread Tools | |
Similar Threads for: Circuit for Hall effect sensor
| hall-effect sensor, need to know resistance | Electrical Engineering | 22 | ||
| Hall Effect Sensor Question | Engineering, Comp Sci, & Technology Homework | 0 | ||
| Using a Hall Effect sensor IC for high fields | Electrical Engineering | 6 | ||
| what is Spin Hall effect and quantum hall effect | Quantum Physics | 1 | ||
| implementing Hall Effect Sensor | Electrical Engineering | 5 | ||
