Interesting problem with possible solution
  • Context: Undergrad
  • Thread starter Thread starter StatusX
    Interesting
The discussion revolves around a mathematical problem involving a seven-digit number and its divisibility by 7 after crossing off digits from either end. Participants explore the validity of a proof related to this problem and delve into the pigeonhole principle as it pertains to the argument presented.
  • One participant presents a proof claiming that at least one of the numbers formed by crossing off digits must be divisible by 7, using the idea that if all are different mod 7, one must be 0 mod 7.
  • Another participant asserts that the proof indeed employs the pigeonhole principle, suggesting that the argument aligns with its logic.
  • Several participants express confusion regarding the pigeonhole principle, debating its definition and application in the context of the proof.
  • One participant questions the validity of their proof and whether speed in arriving at a solution matters in mathematics.
  • Another participant challenges the understanding of the pigeonhole principle, providing different interpretations and examples.
  • There is a discussion about whether the proof is correct, with some participants indicating that it may be valid while others remain uncertain.
Participants do not reach a consensus on the validity of the proof or the interpretation of the pigeonhole principle. Multiple competing views and interpretations remain present throughout the discussion.
Participants express uncertainty about definitions and applications of mathematical principles, particularly the pigeonhole principle, which may affect their understanding of the proof's validity.
StatusX
here's the problem:
You are given a seven digit number. Prove that you can cross off some of the numbers at the beginning or the end and you'll be left with a number that is divisible by 7. For example:
1434945
Cross off the first three and last two to get 49.
I have a proof of this and I want to see if it's valid. I'll post it below, but if you want to solve this yourself don't scroll down.
Here's my proof:
Assume that none of the numbers formed by crossing off the last digit and then any number of other digits are divisible by seven. Then I will show that one of the seven numbers left (ie., those which include the last digit) must be. Take any two of these seven strings. They differ by a power of ten times one of the strings not divisible by 7, so their difference is not divisible by 7. Therefore, they are not congruent mod 7. Since all seven of these numbers are different mod 7, one of them must be equal to 0 mod 7. Is this right? I was told I'd have to use the pigeonhole principle, but I don't think i did. And I thought about the fact that it might be impossible that none of the strings not including the last digit are divisible by seven, which would mean my proof is based on a contradiction, and therefore isn't valid. But if that's true, then it implies the result anyway. Is that a valid method of proof? Second question is, how long should this problem take to solve? I got it in probably about half an hour, without paper, just walking around thinking about it. Does speed matter in math, or is it just that you get the final answer?
You used it here (without realizing it):
i thought the pigeonhole principle was that if you put n+1 objects into n holes, there will be one hole with at least 2 in it. I put n objects in n holes, and by making sure none went in the same hole, I showed that a particular one of them must be full. isn't that different? and moreover, is my proof right?
i thought the pigeonhole principle was that if you put n pigeons into n+1 holes, there will be one hole with no pigeons in it. Or was it that if you put no pigeons into n holes there will be n holes with no pigeons?
are you making fun of me? I am only saying i don't think its the pigeonhole principle cause I am curious if there's another solution. no pigeons in n holes leaves n holes? that's stupid.
*shrug* Seems like practically the same thing to me.
and if one of the numbers weren't 0 mod 7 then you'd have to assign 7 distinct objects to 6 slots. that is the pigeon hole principle. note mathwonk is reversing the labels of holes and pigeons.
o ok, i was just confused cause i thought the pigeonhole principle was for when you had no idea where the pigeons were going, you just wanted to know that two of them were in the same hole. For example, in a sentence with 27 words, at least 2 of the words (probably more) will start with the same letter. What I did would be like somehow proving every word started with a different letter, and saying that in a sentence with 26 words, one of them must start with x. I'm sorry if that's the same and I'm not seeing it, I'm just curious if there's another solution to this problem.
