How can I calculate the lift of a helium balloon?
  • Context: Undergrad
  • Thread starter Thread starter kenewbie
    Balloon Helium Lift
The discussion revolves around calculating the lift of a helium balloon, focusing on the principles of buoyancy, weight displacement, and ascent rate. Participants explore the theoretical and practical aspects of lift generation, including the effects of balloon design and gas properties.
  • One participant suggests calculating the lift by determining the weight of the helium and balloon compared to the weight of the air displaced, proposing that if the helium and balloon are g grams lighter than the air, then the lift is g grams.
  • Another participant mentions the need to consider the composition of air (nitrogen, oxygen, CO2, etc.) to accurately calculate the weight of the displaced gas, referencing standard temperature and pressure (STP) conditions.
  • A third participant agrees with the basic premise and provides a formula for effective lifting force as the difference between the weight of the displaced air and the total weight of the balloon and payload.
  • This participant also introduces the concept of acceleration and terminal velocity, noting that friction will eventually counteract the lift, leading to a constant ascent rate.
  • A later reply questions whether the balloon is elastic or a bag, indicating that if it is elastic, the helium must be pressurized, which could affect the lift due to additional helium needed.
Participants generally agree on the basic principles of lift calculation but present different considerations regarding the effects of balloon type and gas properties. The discussion remains unresolved regarding the specific calculations and assumptions needed for accurate lift estimation.
Limitations include potential missing assumptions about the balloon's material properties, the exact composition of the air, and the effects of pressure on helium lift. The discussion does not resolve these complexities.
kenewbie
Say I want to send a helium balloon into the sky. For all intents and purposes this balloon is circular, with volume V. I will fill it with helium to the same pressure as the air outside it (I assume that this is important). The weight of the balloon and the payload is W.
So, I assume I have to calculate the weight of the helium + balloon, and, somehow, the weight of the air that the balloon replaces. So if the helium and the balloon is g grams lighter than the air would be, then I have g grams of lift?
And how would I go about converting g grams of lift to meters per second?
If anyone can help me out with some ways to calculate this, I would be very grateful. If there are important variables that I have left out, I certainly would appreciate that being pointed out aswell.
k
To calculate the weight of the gas displaced, you have to use the percent mixture of nitrogen, oxygen, CO2 ect. I am pretty sure that at STP the ratio is 24 liters per one mole of gas particles.
For calculating the rate of assent, since you already know the weight of the craft and the lift, just use Force=Mass*Acceleration
Hi. Your statement is essentially right. You've got a balloon with weight W (including the Helium) that displaces a volume V of air. This air has a weight w, so the effective lifting force is equal to w minus W.
F = w - W
Irrelevant a this basic level: the shape of the balloon, the helium pressure. Of course, at greater pressure the He weights more, but this has already been included in the total weight W.
Now, we've got an object of mass M = W / g subject to a force F, so it acquires an acceleration
a = F / M
And therefore, supposing it starts with zero initial velocity , the speed at any time t is equal to:
v = a * t
Of course, in a more realistic setup the acceleration of the balloon is countered by the friction, when the balloon attains its terminal speed, the friction is equal to the lift, and it ceases to accelerate upwards.
Is this an elastic balloon or a bag? If elastic, you'll have to put the helium in under pressure, hence extra helium and less lift.
  • · Replies 22 ·
  • · Replies 18 ·
