| New Reply |
Calculation on Price Elasticity of Demand problem .... Need Advices ..... |
Share Thread |
| Oct27-10, 12:00 PM | #1 |
Give following demand function:
Q = 2.0 P^-1.33Y^2.0A^0.50 Q = Quantity demanded (Thousads of units) P = Prices ($/Unit) Y = Disposable income per capita ($ thousands) A = Advertising expenditures ($ thousands) When P = $2/unit, Y = $8 (i.e. $8000), and A = $25 (i.e. $25000)... 1. Price Elasticity of demand 2. The approximate percentage increase in demand if disposable income percentage increased by 3%. 3. The approximate percentage increase in demand if Advertising Expenditure are increased by 5%. Well, i really not so understand how to resolved the ab0ve question. Is that i need to draft a graft in order to get the answer ??? Hopefully hav some one professional here to guide me on this kind of question . regards, Dream Bell |
| Oct27-10, 12:38 PM | #2 |
Admin
I have no idea about the economy part of the question, but you will not probably get much help, as your post is ambiguous and not clear. I can only guess that equation for Q is given, and points 1-3 are things that you are expected to calculate.
If so, 2 & 3 looks like simple plug and chug. |
| Oct27-10, 12:59 PM | #3 |
For (1) use the definition of price elasticity. This should involve a partial derivative. For 2 and 3 formula use the definition of percent change. (Y2-y1)/Y1*100%. Less formula (for example in 2) you could simply replace Y by 1.03Y and see how this effects Q. |
| Oct27-10, 02:09 PM | #4 |
Calculation on Price Elasticity of Demand problem .... Need Advices .....For number 1, the equation for price elasticity of demand is Ep(Q) = Q'(P) * P/Q. Try to solve for Q'(P) on your own using the formula I gave you in your other post (given Ax^B, d(x) = A*B*x^B-1, and you get to hold Y and A constant when taking derivative with respect to P). From there, you just plug price in for P, and solve for Q given the values in the problem, which you plug into the denominator, and multiply by the derivative with respect to P. This will give you a number between 0 and infinity (typically between 0 and 2), which is the price elasticity of demand. For number 2, you first need to find the income elasticity of demand. This is Ey(Q) = Q'(Y) * Y/Q, and is found the exact same way as price elasticity, just w.r.t. a different variable. Multiply the result by 3 to get the percent change in demand that follows a 3% change in income. For number 3, you are finding the advertising elasticity of demand. This is Ea(Q) = Q'(A) * A/Q. See the trend here? Multiply that result by 5 to get the change after a 5% change in advertising expenditures. I'm sorry if this isn't very clear, but hopefully it helps. Good luck. |
| New Reply |
Similar discussions for: Calculation on Price Elasticity of Demand problem .... Need Advices .....
| Elasticity Problem | Introductory Physics Homework | 8 | ||
| Using calculus to prove a relation between demand elasticity and AR, MR | Calculus & Beyond Homework | 3 | ||
| [SOLVED] Need double check on Price Elasticity Please | Precalculus Mathematics Homework | 2 | ||
| Price Elasticity of Demand and Supply in Sharemarket | Social Sciences | 3 | ||
| price- demand function | Introductory Physics Homework | 1 | ||
