Solving the System Ax = b: Is Full Rank Necessary?
  • Thread starter Thread starter BobSea
    rank System
The discussion centers on the linear algebra problem of solving the system Ax = b, where A is an m x n matrix with m > n. It is established that A must have full rank for a solution to exist, as a lack of full rank implies that b may not lie within the column space of A. A counterexample is suggested, using a simple matrix A composed of standard basis vectors in ℝm, demonstrating that if b is not in the range of A, then Ax = b has no solution.
  • Understanding of linear algebra concepts, specifically matrix rank.
  • Familiarity with the properties of matrix multiplication.
  • Knowledge of the column space and its significance in linear systems.
  • Basic experience with constructing matrices and vectors in ℝm.
  • Research the concept of matrix rank and its implications on linear systems.
  • Study the properties of the column space of a matrix.
  • Learn about the standard basis vectors in ℝm and their applications.
  • Explore counterexamples in linear algebra to solidify understanding of solution existence.
Students and educators in linear algebra, mathematicians, and anyone involved in solving systems of linear equations.
BobSea
The system Ax=b, with Amxn, and m>n, always has a solution when A has full rank. If False, give a counter example, if True, say why.
None
I want to say False because b doesn't need to be in the range of A, so Ax=b wouldn't have a solution. However, I'm having trouble making a counter example (i.e. A = 3x2 matrix and b = 3x1 matrix) that proves the point.
Your reasoning is correct. For a counterexample, try a very simple A whose columns are elements of the standard basis for [itex]\mathbb{R}^m[/itex].
  • · Replies 32 ·
