Mean drift velocity of a conduction electron in copper.
The mean drift velocity of a conduction electron in copper, calculated using a No. 14 wire carrying 5A, is approximately 0.018 cm/s. This calculation utilizes the formula I = nAqvd, where the number density of conduction electrons is derived from the density of copper (8.94 g/cm³) and its molar mass (63.546 g/mol), resulting in 8.47 x 10²² atoms/cm³. Despite the slow drift velocity, electric signals propagate through the wire at the speed of light, explaining the instantaneous illumination of electric lights when a switch is flipped.
  • Understanding of electric current and drift velocity
  • Familiarity with the formula I = nAqvd
  • Knowledge of atomic density calculations
  • Basic principles of electric fields and signal propagation
  • Study the relationship between electric field strength and electron mobility
  • Explore the concept of signal propagation speed in conductors
  • Learn about the properties of different conductive materials, focusing on copper
  • Investigate the effects of temperature on conductivity and drift velocity
Physics students, electrical engineers, and anyone interested in the fundamentals of electrical conduction and the behavior of electrons in conductive materials.
Minakami
Estimate the mean drift velocity of a conduction electron in copper, assuming that there is one conduction electron per atom. Consider No. 14 wire (diamter 0.16 cm), common in houses, carrying 5A. The result should be very small. Why then does an electric light turn on almost instantly when you flip the switch?
I = qnLvd=nAqvd
Density of copper = 8.94 g/cm3
Molar mass = 63.546 g/mol
amount of copper per cubic cm:
Density/Molar mass = 0.14068 mol/cm3 = 8.47 x 1022 atoms/cm3
so
vd = I/nAq = (5 A) / (8.47 x 1022 atoms/cm3)(pi * 0.08 cm)2(1.609 x 10-19 C)
= 0.018 cm/s
Did I do this correctly? And I have no idea about the second question...
Your calculation is fine and the answer is about what I would expect.
The electron drift velocity is very slow, but they move in response to the applied electric field. The field is transmitted through the wire at the speed of light.
9K
